Ayo Pilih yang mana???
Handy
Post by Handy »
klo di suruh pilih antara dua motor di bawah ini, mana yang anda pilih :big_smoking:
Honda CBR250RR (1994)
Spec:
Make Model
Honda CBR 250RR
Year
1994
Engine
Liquid cooled, four stroke, Transverse four cylinder, DOHC, 4 valve per cylinder.
Capacity
249
Bore x Stroke 48.5 x 33.8 mm
Compression Ratio 11.5:1
Induction
Ignition / Starting
CDI / electric
Max Power
40 hp 29.2 kW @ 14500 rpm
Max Torque
23.5 Nm @ 11500 rpm
Transmission / Drive
6 Speed / chain
Gear Ratio 1st 2.733 / 2nd 2.000 / 3rd 1.590 / 4th 1.333 / 5th 1.153 / 6th 1.035
Front Suspension
37 mm telescopic fork
Rear Suspension
Monoshock Box Section Swingarm
Front Brakes
2x 275mm discs 2 piston calipers
Rear Brakes
Single 220mm disc 1 piston caliper
Front Tyre
110/70-R17
Rear Tyre
140/60-R17
Seat Height 735 mm
Dry-Weight
143 kg
Fuel Capacity
13 Litres
Kawasaki Ninja 250R (2008)
Spec:
Make Model
Kawasaki Ninja 250R
Year
2008
Engine
Liquid cooled, four stroke . parallel twin, DOHC
Capacity
248
Bore x Stroke 62 Ñ… 41.2mm
Compression Ratio 11.6:1
Induction
2x Keihin CVK30
Ignition / Starting
TCBI with Digital Advance / electric
Max Power
Max Torque
21.7 Nm 2.21 Kg-m 16.0 lb-ft @ 10000 rpm
6 Speed / chain
Frame / Rake/Trail Semi-double cradle, high-tensile steel, / 26 degrees / 3.3 in.
Front Suspension
37mm hydraulic telescopic fork
Rear Suspension
Uni-Trak® with aluminum linkage
Front Brakes
Single 260mm hydraulic petal disc 2 piston caliper
Rear Brakes
Single 220mm petal disc 2 piston caliper
Front Tyre
110/70-17
Rear Tyre
130/70-17
Seat Height 780 mm
Dry-Weight
151 kg
Fuel Capacity
18.2 Litres
ホンダ NSR レヌ バィク
Diki_Oke_Deh
Re: Ayo Pilih yang mana???
Post by Diki_Oke_Deh »
Desain Kawasaki lebih fresh , tapi hanya punya 2 silinder.Sementara Nsr 4 silinder melintang.ehm...pikir dulu mode on..... :e-doh:
123stu
Post by 123stu »
biar jadul, tapi orang pada nengok kalo tuh motor lewat bro.... :e-dance:
eNeR
Post by eNeR »
liat dari speknya, lebih mantap yg honda ntu deh, apalagi lebih ringan CBR, vote to CBR, biar jadul yg penting mak nyus lah,
spin022
Post by spin022 »
gw lebih pilih vtr250 daripada cbr250rr, masih diproduksi, european style pula
DRoze
Post by DRoze »
Dari segitu lamanya perbandingan tahun masih aja harganya nda beda jauh hmm ninja karena untuk pemakaian jangka panjang dan nda usah ganti2 motor lagi dan perawatan pastilah lebih murah walaupun awal2 ninja lebih mahal.
Handy
Post by Handy »
diantara 2 motor ini pasti ada plus minus nya.
CBR yang pasti performance lebih top tapi kan perlu restorasi mesin utk kembali ke kondisi yang top. trus design CBR juga soprty bgt kental model motor sport jaman tahun 90an bandingin sama ninja 250 thn 98 yang modelnya masih culun. dan lagi CBR250 pakai chasis yang bener2 sporty bgt di dukung double disk depan dan yang paling penting posisi setang bener2 motor sport beda dengan ninja 250 yang design sporty tapi setang tinggi bgt
ninja 250 yang baru ini design nya cukup menarik tapi ya itu posisi setangnya tinggi. maklum lah ini kan bukan zx-r tapi gpx250r basicnya sport touring beda dengan CBR yang konsepnya memang sport. dan lagi body ninja 250 terlalu di gembungkan padahal klo di buka mesinnya ngak begitu penuh. klo ada yang pernah liat CBR 250 di buka fairingnya bisa bedain deh mesinnya gede jadi isi dalam fairing penuh semua.
ホンダ NSR レヌ バィク
ahardo
Post by ahardo »
pengen 2 2nya aja :D
Turbo Hayabusa
