The coolest Hybrid Sedan: Toyota Prius 2
Herry
Post by Herry »
Toyota Prius 2 is the best hybrid sedan in the world.
Exterior Dimensions (in.)
Overall height/width/length 58.1/67.9/175.0
Wheelbase 106.3
Track (front/rear) 59.3/58.3
Coefficient of drag (Cd) 0.26
Ground clearance 4.9
Interior Dimensions front/rear (in.)
Head room 39.1/37.1
Shoulder room 55.3/53.0
Hip room 51.0/51.6
Leg room 41.9/38.6
Capacities
Curb weight (lb.) 2890
Seating capacity 5
Passenger volume (cu. ft.) 96.2
Luggage capacity (cu. ft.) 16.1
Fuel tank (gal.) 11.9
Hybrid Synergy Drive®
Gasoline Engine
Type Aluminum double overhead cam (DOHC) 16-valve
VVT-i 4-cylinder
Displacement 1.5 liters (1497 cc)
Bore x stroke 75.0 mm x 84.7 mm
Compression ratio 13.0:1
Valvetrain 4-valve/cylinder with Variable Valve Timing with intelligence (VVT-i)
Induction system Multi-point EFI with Electronic Throttle Control
System with intelligence (ETCS-i)
Ignition system Electronic, with Toyota Direct Ignition (TDI)
Power output 76 hp @ 5000 rpm (57 kW @ 5000 rpm)
Torque 82 lb.-ft. @ 4200 rpm (111 Nm @ 4200 rpm)
Emission ratings Advanced Technology Partial Zero Emission Vehicle (AT-PZEV) [1]
Electric Motor
Motor type Permanent magnet AC synchronous motor
Power output 67 hp @ 1200-1540 rpm (50 kW @ 1200-1540 rpm)
Torque 295 lb.-ft. @ 0-1200 rpm (400 Nm @ 0-1200 rpm)
Voltage 500V maximum
Traction Battery
Type Sealed Nickel-Metal Hydride (Ni-MH) [2]
Power output 28 hp (21 kW)
Voltage 201.6V
Hybrid System Net Power 110 hp (82 kW)
Mechanical/Performance
Transmission Electronically controlled continuously variable transmission (ECVT)
Suspension
Front Independent MacPherson strut with stabilizer bar
Rear Torsion beam with stabilizer bar
Steering Rack-and-pinion with electric power-assist
Turning circle (ft.) 34.1
Brakes Power-assisted ventilated front disc/rear drum with Anti-lock Brake System (ABS) and integrated regenerative braking
Mileage Estimates
(mpg city/highway/combined) 60/51/55 (mile per gallon)
Herry
Post by Herry »
Toyota Prius 2 interior and cargo room.
Herry
Post by Herry »
Cool, smart and cute dashboard.
Chalupa
Post by Chalupa »
Kalo Accord V6 Hybrid sudah keluar, bisa terancam nih Prius II. Accord V6 Hybrid jauh lebih unggul daripada Prius II di banyak hal. Udah begitu, Accord juga mid-size sedan. Wah, bakal seru nih kalo Accord V6 Hybrid udah diluncurkan.
conan
Post by conan »
The thing is, the accord hybrid looks like..an accord. The Prius looks futuristic and it screams 'Hybrid!'. Prius owners don't even have to say a word, people will take a good look everywhere they go. Meanwhile, Accord hybrid owners are busy explaining to their fellow Accord-owning neighbours that their Accord is different :P
pinoh_boy
Post by pinoh_boy »
Kekekeke. No wonder about it!
DigitALL
Post by DigitALL »
Prius 1 atau 2 mau diliatin terus2an kaga bosenin ya. Modelnya emang manis dan futuristik sekali.
Chalupa
Post by Chalupa »
Ngomong-ngomong soal Hybrids keluaran Toyota yg berbentuk futuristic, ini ada satu Hybrid Sports Car (masih berupa concept) dari Toyota, yg bentuknya juga rada futuristic:
http://www.serayamotor.com/diskusi/viewtopic.php?t=1006
