Ford XR6T Beyond 1000hp!
asdw
Post by asdw »
1035hp from a Ford XR6T engine
Fat, useable torque curve
High strength internals
7500 rpm limit
AUD$40k+ build
If there’s one thing we’ve learnt about Simon Gichus of Nizpro it’s that he’s more than willing to spend the time and money developing the most super-duper tuned engines.
With a last run of 1035hp – running a mild 23 psi boost and with Mobil 98 RON fuel – Simon has been the first to crack the magic tonne. Interestingly, Simon says there will be quite a few people making big power with XR6Ts in the next few years. “We wanted to get in early and develop something that will make that 1000hp figure while still holding together and being nice an’ driveable,” he says.
Simon was drawing on his wealth of experience tuning Nissan RB-series engines when he tackled the new Ford six. “At 4.0 litre it’s a big engine and, in that context, it can rev alright with the right gear – we plan on taking it to around 8000 rpm.” And that takes us to one very important point. Simon says that achieving 1000hp+ reliably calls for a fine balance of torque and revs.
“We’ve held to an 800ft-lb torque limit, which we aim to get up to and maintain as far through the rev range as possible. This should protect the rods and various other parts of the engine, compared to sticking in more and more boost and watching torque go up,” he says.
With this in mind, the engine has been built to withstand high rpm as well as huge torque
Mesin 4000 cc, HP 1035, Torsi 110 kg/m. Hmmmm.... sebaiknya dipasangin di bodi mobil apa ya?
Crash
Re: Ford XR6T Beyond 1000hp!
Post by Crash »
asdw wrote:Mesin 4000 cc, HP 1035, Torsi 110 kg/m. Hmmmm.... sebaiknya dipasangin di bodi mobil apa ya?
Di body mobil Ford Falcon XR6 Turbo, lah. Abis, asalnya kan dari sono.
Nih, mobilnya liat aja sendiri:
http://www.ford.com.au/showroom/passeng ... hicles.asp
Abis itu klik di "Falcon Range", dan cari XR6. Di situ elo bisa lihat specnya. Itu sih sedan gede, lebih gede daripada camry.
