Karena beli 2nd jadi tidak tahu kapan kampas rem terakhir kali diganti. Yang ingin ane tanyakan apa tanda/ciri kampas rem sudah saatnya diganti baik yang tromol maupun disc.
gini, untuk gampangnya tau kalo kampas rem minta diganti :Kaleng wrote:Ane beli mobil jazz idsi A/T 2nd. Semenjak beli sampai sekarang sudah menempuh +-15.000km. Rute perjalanan jarang kena macet.
thx utk gambarnya om. ntar weekend mo coba cek. yg gambar rem tromol itu yg dilihat apanya ya? ketebalan kampasnya atau ada indikator line?asudarsono wrote:Kalau oli rem kurang emang bisa nabrak depannya.
Kalau mau cek ketebalan rem, dilihat aja, paling buka ban juga udah bisa kelihatan. Tinggal intip aja sesuai foto di bawah.
http://www.fitfreak.net/forums/fit-susp ... rakes.htmlYour rear brakes are self-adjusting as are all drum brakes. To check for need for replacement, take off your wheel(s) with the rear up on jack stands, release the parking brake, and pull off the drum(s). The front brake shoe is the primary, rear is the secondary shoe. The primary is smaller, and wears faster than the secondary. The Honda Fit service manual will tell you how to measure the lining thickness on the shoes, but in general if either shoe is worn down to about 1/16", it's time for replacement.
I looked it up for you. Replace shoes when linings are worn to 2mm (.080"). My guess of 1/16" was a little too late (.0625"). The linings are glued to the metal shoes. If they wear too thin, they get hot enough to have the glue fail and the linings fall off, leaving you with metal-to-metal contact and NO stopping power at all. Now you need two new drums too.
bro.. yang dimaksud besi tipis itu yang lempengan plat gitu bukan????inoz wrote:ane mo share
kamarin sebelum mudik ane cek dan bersiin kampas rem bpil santa fe anekm sudah 89.000 km dan belum pernah ganti sebelumnya.
klo yg disk di depan, tebal tipisnya brake shoe bis dilihat dari samping, emang di kampasnya ada semacam besi pipih gitu, jadi klo dah tipis sementara kita bgak pernah cek akan ada bunyi
klo tromol yg blakanmg gak ada solusi mesti dibuka tutup nya baru bs kelihatan ketebalan dr kampas remnya, skalian cek saluran dan pompa oli rem gak bocor, ternyata ada rembesan makanya, diganti aja seilnya cuman rp 5000, skarangdah siip pakem...
Mercy dan BMW juga ada sensornya om andy, jadi setiap ganti kampas rem baru sensornya juga ganti baru.andy1800 wrote:o iya.. di pug....salah satu merk partsnya: valeo....
jd enak, kalau mulai tipis, ada nyalanya di panel indstrumen...
klo mobil lain, ada gak yg ada sensornya kaya gitu ?
