keyless entry hacked
bushkntl
Post by bushkntl »
Car thieves of the future might be able to get into a car and drive away without forced entry and without needing a physical key, according to new research that will be presented at the Network and Distributed System Security Symposium next month in San Diego, California.
The researchers successfully attacked eight car manufacturers' passive keyless entry and start systems—wireless key fobs that open a car's doors and start the engine by proximity alone.
Srdjan Capkun, an assistant professor of computer science in the system security group at ETH Zurich in Switzerland, who led the work, says he was inspired to investigate the security of keyless entry and start systems after buying a car that had one. Capkun and Aurélien Francillon and Boris Danev, both researchers in the same institution, examined 10 car models from the eight manufacturers. They were able to access all 10 and drive them away by intercepting and relaying signals from the cars to their wireless keys. While they could relay the signals from the key back to the car as well, usually they did not need to because the key transmits its signals up to around 100 meters. The attack works no matter what cryptography and protocols the key and car use to communicate with each other.
Normally, when a wireless key is within a few meters of the right car, it detects a low-powered signal that causes it to issue a command that opens the car enable the ignition. The researchers used a pair of antennas to transmit these signals from the car to the key when the key was farther away, tricking the car into opening without the ordinary authorization. One antenna needs to be very close to the car, and one needs to be within eight meters of the key.
sisanya baca disini http://www.technologyreview.com/computi ... page1/?a=f
Re: keyless entry hacked
jadi inget jaman dulu ada yg namanya pake kumparan elektromagnetic buat matiin alarm2 mobil2 jadul....
bushkntl
Post by bushkntl »
kalo mo aman pake caranya Mr Bean aja kali ya :mrgreen:
esh
Post by esh »
Berarti masih lebih aman sistim immobilizer daripada keyless entry. :e-think:
Mungkin berikutnya bisa ditambah fingerprint recognition kali. :upss:
m4rio
Post by m4rio »
kalo bisa ditambahkan juga sensor suara, jadi yang bisa idupin mesin cuman suara 1 orang dengan kalimat, nada dan penekanan suara yang benar2 pas. beda sedikitpun gk bakal idup.
mungkin gk ya pake gitu???? hehehehehehe
Itu mah malah membahayakan yg punya. Misalnya anak kuliahan ce...malah ditodong disuruh fingerprint atau ngomong ke mobilnya supaya bisa start. Paling bagus sih asuransi aja, kalo cuman barang yg hilang kan gpp...
kapsul 97
Post by kapsul 97 »
FortunerMan wrote:Itu mah malah membahayakan yg punya. Misalnya anak kuliahan ce...malah ditodong disuruh fingerprint atau ngomong ke mobilnya supaya bisa start. Paling bagus sih asuransi aja, kalo cuman barang yg hilang kan gpp...
setuju Oom, hari gini emang paling pas asuransi .. minimal TLO lah, kalu ngga mah repot ...
kemarin aja baca di detik.com komplotan pencuri mobil, mereka khusus nyuri avanza dan innova, mereka cuma butuh waktu 5-10 menit untuk maling tuh kendaraan, gile bener yaa... tapi kalu waktu nya dah lebih dari itu dan mereka ga berhasil akan mereka tinggalin ...
Iya saya juga baca tuh...dijualnya di daerah murah banget lagi...gak sampe 20 juta :mrgreen:
kapsul 97
Post by kapsul 97 »
iya Oom, avanza 12 juta, innova 18 juta ..
kapsul 97 wrote:iya Oom, avanza 12 juta, innova 18 juta ..
+uang buat menyulap jadi barang halal...jadi deh
esh
Post by esh »
m4rio wrote:kalo bisa ditambahkan juga sensor suara, jadi yang bisa idupin mesin cuman suara 1 orang dengan kalimat, nada dan penekanan suara yang benar2 pas. beda sedikitpun gk bakal idup.
Berarti kalau lagi flu nggak bisa pake mobil :upss:
makanya ane takut beli toyota.... :ngacir:
m4rio
Post by m4rio »
kalo switch pengaman gmn tuh? pengaruh banyak gk???
kapsul 97
Post by kapsul 97 »
maskopat wrote:makanya ane takut beli toyota.... :ngacir:
kenapa juga gitu harus Toyota?
:big_slap:
Barang laku...gak ada immobilizer....empuk buat maling. Itulah gunanya asuransi...
m4rio
Post by m4rio »
paling pas menurut ane Kalo mau ambil TLO lengkap dengan TJH min 10jt gitu.
bushkntl
Post by bushkntl »
Emang harga imobilizer brp ya? Sampai toyota gak mau pasang di avanza/kijang?
Note: toyota haters gak usah ikut jawab
asudarsono
Post by asudarsono »
2 juta rupiah
Ready to Race
bushkntl wrote:Emang harga imobilizer brp ya? Sampai toyota gak mau pasang di avanza/kijang?
Innova skrg ada kok. Avanza yah...harga ekonomis, Suzuki APV...Hyundai Avega juga gak ada. Cuman yg inceran maling ya yg demandnya super tinggi.
bushkntl
Post by bushkntl »
Mungkin yg tipe v kali ya bro? Innova gw type g tahun 2010 5 bulan lalu dibawa maling begitu aja alarm kagak bunyi sama sekali :mrgreen:
Iya yg tipe atasnya. Yaris juga gitu kalo gak salah...
m4rio wrote:paling pas menurut ane Kalo mau ambil TLO lengkap dengan TJH min 10jt gitu.
ane sih daripada mobil pake asuransi dimaling, lebih milih mobil gak pake asuransi gak dimalingin.... :big_weee:
m4rio
Post by m4rio »
semua juga maunya begitu bro, ngmg2 mobil bro di asuransi ya?
BADAK
Post by BADAK »
Om kopat mobilnya diasuransi, tapi orangnya kagak :big_weee: :big_weee:
Live as if you'll die today
bushkntl
Post by bushkntl »
asudarsono wrote:2 juta rupiah
mungkin lebih dari 2 juta kali bro kalo cuma segitu gw rasa gak ada masalah untuk konsumen varian bawah avanza/inova/apv dll untuk tambah 2 jt daripada pusing ama asuransi dan maling
