Fortuner peslip India pakai VSC (Stability Control)
Mantappp !!
http://www.toyotabharat.com/cars/new_ca ... ation.aspx
http://www.toyotabharat.com/cars/new_ca ... index.aspx
Saya bisa bilang mantap, karena pernah merasakan test slalom 42ner TRD Sportivo 4X4 dgn VSC, memang benar2 sangat membantu manuver mobil tinggi spt ini.
solar_kerosen
Re: Fortuner peslip India pakai VSC (Stability Control)
Post by solar_kerosen »
^ atas gue , cobanya dimana om dan mobil IU apa TAM punya :mky_01:
solar_kerosen wrote:^ atas gue , cobanya dimana om dan mobil IU apa TAM punya :mky_01:
di salah 1 negara ASEAN
asudarsono
Post by asudarsono »
Harusnya Avanza pakai ginian
Ready to Race
Lucky11
Post by Lucky11 »
Dari harganya avanza ga mungkin dikasih yang ginian kayaknya...
asudarsono
Iya, harus ABS dulu
Ready to Race
Turboman wrote:Mantappp !!
Waduhh mohon maap, nubie yang kolot ini ngga ngerti tuh om...
VSC tu apa ya? Apa kaitan VSC ama manuver mobil tinggi..?
:thanks:
Vehicle Stability Control om
solar_kerosen
Lucky11 wrote:Dari harganya avanza ga mungkin dikasih yang ginian kayaknya...
bisa aja kalau Ak4ng request khusus sama TAM :big_weee:
FortunerMan wrote:Vehicle Stability Control om
Oh, many thanks, om... lebi baeg menyimak aja dulu ahh.....
Menyimak tret bergizi...
:off_sleep: :off_sleep:
And45
Post by And45 »
:thanks:
vsc tu vehicle stability control kan?
fungsinya biar mobil nga kebalik
cmiiw
salam newbie
VSC ----->toyota = VSA ----->honda
cmiiw :e-think:
ASC ---> BMW http://www.bmw.com/com/en/insights/tech ... ntrol.html
On uneven or slippery road surfaces the Automatic Stability Control (ASC) system ensures you can accelerate out of each bend safely and with maximum traction.
Automatic Stability Control (ASC) is an element of the Dynamic Stability Control (DSC) system. It prevents loss of traction on the drive wheels when setting off, when accelerating out of curves and in other critical moments. When one wheel has good traction but the other is on a slippery patch of road, the wheel with less traction is braked until it is again able to gain a grip on the road surface.
If both wheels lose traction, the engine management system also intervenes and reduces the power output, which significantly reduces the danger of the rear of the vehicle skidding out. The entire process takes place in milliseconds.
Thus ASC quickly brings the vehicle back to stability and restores traction. Drivers wishing to attain a degree of wheel slip, for example when aiming to have a certain amount of "drift", can disengage ASC if desired.
Sudah ada di si jadul E39 - tapi belon pernah kepake...wong bawa mobil kaya nenek2 wkwkwkwk...
asudarsono wrote:Harusnya Avanza pakai ginian
ga perlu.... 180 kmh masi stabil....
Komeng superduper ngasal atas ane. Coba dulu Euro brand, yang jadul sekalipun, baru bisa bilang 150 KMH up tetep mantep gak melayang goyang dombret kek (mostly) Jepangan.
uda coba bbrp ... wajar aja stabil... berat gitu... mobil ga efisien.... power mesin abis sama berat mobil itu sendiri... capede...... meningan apanja ane kemana2... toh ttp ga menjamin selamat kan kalo celaka...
asudarsono
Akang dibelain, kok malah nolak sih. Orang lain seneng dan bangga kalau mobilnya fiturnya lengkap.
Ready to Race
kirain lama ga nongol udah rada pinteran dikit :wkkk: :wkkk:
tau nya masih sama aja kaya luak :big_weee:
masih lebih pinter luak malah :big_weee:
asudarsono
Kalau Akang luwak, Nescafe anaknya dong?
Ready to Race
Di kecepatan rendah nyetir sendiri emang lebih enak mobil Jepang. Nyelap nyelip di Jakarta nyetir sendiri, I'll take a Japanese - ringan nan lincah. Kalo duduk dibelakang ya tergantung mobil Eropanya. Kalo yg premium brand ya jelas enak - harganya udah jauh.
Camry vs E39 dalkot Jakarta misalnya - I'll take a Camry. Jauh lebih lincah. Luar kota, jalan liuk2 high speed...buang aja Camrynya wkwkwk.
FortunerMan wrote:.buang aja Camrynya wkwkwk.
sini2... ane siap tampung.... lumayan jadi mobil operasional ane... naik pangkat dikit... :mky_02: :mky_02: :mky_02: :mky_02: :mky_02:
FortunerMan wrote:Di kecepatan rendah nyetir sendiri emang lebih enak mobil Jepang. Nyelap nyelip di Jakarta nyetir sendiri, I'll take a Japanese - ringan nan lincah. Kalo duduk dibelakang ya tergantung mobil Eropanya. Kalo yg premium brand ya jelas enak - harganya udah jauh.
apalagi papanjahnya ak4ng.... mungkin bukan dibuang kali.... :mky_03:
MPV kok dipaksain jadi sportscar tho kang??? Aya aya wae eta mah! :mky_07:
Toyota emang enak dijadikan mobil operasional - dr Habanja sampe Camry sampe Crown sampe Landcruiser. Bedanya cuman mewahnya - reliability tetap top notch di seluruh jajaran.
doq wrote:kirain lama ga nongol udah rada pinteran dikit :wkkk: :wkkk:
Hansen wrote:masih lebih pinter luak malah :big_weee:
meningan ente berdua buktikan kalo lebih pinter dari ane.... ini kan forum diskusi.. seharusnya berbagi ilmu dan pengalaman donk... bukan kek post di atas yg ane quote... :mrgreen: :mrgreen:
