Andai teknik Modif / aplikasi modif ini ada di Indonesia
WPC engine parts treatment :
http://www.wpctreatment.com/about.htm
http://www.wpctreatment.com/documents/Why_WPC.pdf
WPC achieves this process by firing ultra fine particles towards the surface of a product at very high speeds. The resulting thermal discharge permanently changes the surface, strengthening structure and creating a harder more durable final product.
Spearco Intercooler Cores
Spearco Liquid to Air Intercooler Core
W.A.V.E. Technology (Wide Area Vane Effectiveness) is the ultimate combination in strength and efficiency of heat exchanger cores. Specifically designed to maximize cooling by utilizing the most surface area possible in a given space. The Spearco W.A.V.E. core incorporates a complex network of highly effective vanes to regularly decrease temperatures by as much as 30º F over conventional tube n’ fin units. In addition to their phenomenal cooling ability, W.A.V.E. Technology cores are manufactured to be nearly “BOMB PROOF.”
Due to Spearco’s manufacturing process, these unique cores are capable of comfortably withstanding pressures in excess of 200+ psi. W.A.V.E. Technology cores set the standard for high-pressure forced-induction durability and cooling effectiveness. Whether you are a high performance enthusiast or a pro drag racer seeking the peace of mind to make the next round. The W.A.V.E. Technology intercoolers and radiators are for you.
Extrude Hone
Pemolesan saluran2 dengan pasta abbrasive
http://www.kennametal.com/kennametal/en ... ement.html
Yok silakan ditambahken :mrgreen:
Re: Andai teknik Modif / aplikasi modif ini ada di Indonesia
extrude hone, berapa biayanya kalo ada di indonesia? paling murah, ya amplas. plus tensoplas buat ngebungkus jari yang luka.....
POS VETT
Post by POS VETT »
Terlalu mahal, ndak ada yang mau bayar.
Tom
"PRIK NSD"
"WAHJUDI"
"POS VETT"
"YELO NEK"
"AINT YRS"
ola_comoesta
Post by ola_comoesta »
Susah diminati mungkin..Modifnya indonesia Itu yg harus tampak dan dirasakan oleh indera. Seperti mata (ban besar, ceper, bodykit besar) , telinga (knalpot bersuara gahar, turbo whistle) hahahh
glendotan
Post by glendotan »
Paling demen modif2 yang beralasan efisiensi dan memaksimalisasi....jelas kepake dan ada manfaatnya.. btw ane baru tau ada teknik2 seperti diatas...
Thread yang sangat bagus buat menambah ilmu...
ola_comoesta
Iya harusnya modif yg jenis bersifat menyempurnakan gni penting, karena pabrikan mobil kan mass production, dimana partnya juga not 100% perfect, biarpun ada qc. Tpi jeleknya kadang klo ane takut bongkar2 gni, biasanya karena bengkel2 klo g kenal, waduh, kebablasan atau ngembaliinnya g bener bakalan repot.
glendotan
Post by glendotan »
Memang sih harus bengkel yang terpercaya dan memiliki reputasi baik di bidang ini.. tapi ga semua pabrikan mobil juga bisa diefektifkan.. klo brand eropa konon semua sdh baik dan matang. Malah klo di aneh2 suka hasilnya drop. Cmiiw
