Macan S
Macan Turbo
Engine at launch:
3.6L V6 Twin Turbo 394 hp, 405 lb-ft
3.0L V6 Twin Turbo 335 hp, 338 lb-ft
3.0L V6 Turbodiesel, 254 hp, 427 lb ft
http://www.autoblog.com/2013/11/20/2014 ... -pictures/
oleh VW, macan ini mmg tdk diposisikan utk bersaing head to head sm Evoque kan?esh wrote:Kalau lihat spesifikasi engine, harga jual type terendah akan di atas 1,5 M. Jangan mimpi harga bisa bersaing dengan RR evoque.
andy1800 wrote:^ smpai skrg (ppnbm blm naik kan ya?) biasanya pada taroh list price on the road: 1.975 - 2.100
all which come with a seven-speed PDK ‘box as standard.
All are four-wheel drive, a rear-biased system that varies torque across the back axle, and if that doesn’t work, can shunt up to 100 per cent of grunt to the front wheels.
Three usual suspension set-ups are also available, ranging from the basic standard steel springs to full four-corner air suspension.
The smallest wheels available are not-so-modest 18-inchers.
bisaagrandscenic wrote:kok tampak seperti Panamera dengan atap dan GC yg lbh tinggi ya..
