Hyundai 1.8 TwinCharged engine (TC + SC)
the GDCI engine in development uses a supercharger for "low exhaust gas temperatures" and then a turbocharger for "high-speed power." Combined with an extremely high compression ratio – 14.8:1 – as well as a fully variable valvetrain, Hyundai expects a 1.8-liter GDCI engine to be more efficient than a comparable 2.0-liter diesel engine with similar performance.
"Gasoline is possibly the best fuel for diesel engines," Engineer said. Adding to that, John Juriga from Hyundai's powertrain engineering team told us that the target here is to "beat diesel" in terms of cost to the consumer. Flat out, Juriga said that diesels "don't make economical sense to the consumer," and that this GDCI engine will offer the fuel efficiency and performance benefits of diesel without the added price premium. With a current redline of only 4,500 rpm, it also appears like it will behave like a diesel, if not sound like one, though Hyundai tells us it "can soften the noise with injection timing."
This new GDCI engine is being developed with the help of Delphi, and while official production timing hasn't been released,
http://www.autoblog.com/2013/11/15/hyun ... an-diesel/
mari kita tepuk tangan utk terobosan yang berani ini
:mky_02: :mky_02: :mky_02: :mky_02: :mky_02:
ammophobia
Re: Hyundai 1.8 TwinCharged engine (TC + SC)
Post by ammophobia »
VW mundur, Hyundai menggantikan, semoga bisa terus berinovasi dan memberikan mesin yang semakin powerful dan efisien
saya masih belum ngerti dengan perpaduan SC+TC. apakah dengan SC saja kurang mumpuni untuk "high-speed power"nya?
billyd1773dz
Post by billyd1773dz »
GDCI itu kan mesin gasoline yang gak pakai busi kan??
*gasoline direct-injection compression ignition*
pernah ada yg bikin treat nya di SM
imho terobosan yg mind blowing bukan sc+tcnya tp mesin bensin yg ga pke pengapian... .atau mesin diesel pke bahan bakar gasoline wkwkw :D tergantung liatny dari mana... haha :D
imho S/C ane sih rada kurang sreg, karna efisiensinya kurang.... pasti uda pada tau knp..
mending biturbo twinscroll aja. wkwkwk :D
:beer:
Image Billyd1773dz
billyd1773dz wrote:GDCI itu kan mesin gasoline yang gak pakai busi kan??
:beer:
Mirip kayak Diessotto nya Merc yg bbrp tahun lalu yang menggemparkan dunia persilatan ya om? :ungg:
Kemana ya itu enjin? Menjanjikan sekali baik output dan FC nya... :ungg:
billyd1773dz
:beer:
baru denger yg diesel otto, langsung googling hebat juga yah... :D 1.8ltr 235hp 400Nm hehe :D dan yg ini pke twin VGT turbo. bearti suhu EGT setingkat dengan diesel. klw g salah rev limitnya juga d 4500 rpm mirip diesel.
uda dari 2007 g ada kabar lagi yah...... skrng hyundai yg bikin.
karakternya lebih ke diesel cuma fuelnya lebih murah...
klw Cetana number makin tinggi makin cepet kebakar /ignition delay makin rendah saat d tekan. bearti klw pke gasoline fuel lebih baik yg ron rendah karna lebih cepet kebakar... bener engga... hehehe :D ron 88 lagi nih...
:beer:
Image Billyd1773dz
omsafety
Post by omsafety »
Mlipir di marih ah, trit bergizi penuh ilmu :mky_01:
dieselkiki
Post by dieselkiki »
bro billy mo nanya..
twinscroll turbo itu turbo yang model gimana ya ? bedanya dengan turbo biasa apa ? apa kelebihannya ?
sori nanya langsung tanpa gugling..lg pgn disuapin aja inponyah
- faith humanity freedom -
billyd1773dz
dieselkiki wrote:bro billy mo nanya..
kya gini om..
intake exhaustnya di bagi 2.. untuk mobil 4cyld dari cyld 1 dan 4 , 2 dan 3 nyatu masing2 diarahin ke turbine blade.
tujuannya agar flow pulse dari cyld yang berada di cycle pembuangan tidak terganggu dengan cyld yang sedang dengan di cycle nyedot fresh air, which is valve exhaust nya juga ngebuka berbarengan *overlapping* untuk ningkatin scavenging effect / ngebantu dan mempercepat nyedot udara dari intake.
exhaust pulse pada 1 cyld... peak pertama energi burst pulse dari pembuangan cyld di ikuti vakum setelah burst keluar.. kemudian saat valve overlapping terjadi, kembali jadi vakum. vakum ini lah yg di coba di kurangin agar tidak menggangu burst pulse dari cyld lain
exhaust pulse jika 4cyld disatukan
jadi cyld yang berpotensi ngeganggu di pisah jalur ke turbonya. hasilnya pulse dari cyld yang ngedorong turbo flownya lebih kuat,terus ada dan tdk terinterferensi vakum dari cyld lain . efisiensi turbo ningkat
twinscroll 1-4 dan 2-3 di pisah
karna valve overlap uda gmasalah di highrev valve overlap bisa di tambah durasinya scavenging effect jadi lebih baik.
twinscroll turbo yg rumit BMW V8 bi-Turbo crossbank
V8 jadi ngambil cyld yg bebas interferensi harus ngambil dari cyld di bank yang beda. turbonya jadi di simpan di tengah.
semoga berguna... :D
:beer:
Image Billyd1773dz
Nubie menyimak trit penuh gizi...
Makasih atas ilustrasi nya om billy... :mrgreen: ane baru tau kl twin scroll seperti itu. Ane pikir dua kipas dalam satu turbo.
Ternyata lebih rumit... :mky_01:
Twin scroll sama aja ama Turbo biasa tapi port jalur masuk exhaust dr header-nya ada 2, jadi Turbine housing-nya menjadi perpanjangan header.......
itu aja sih intinya
Kalau yg mantap sih spt di bawah ini :
Twin Scroll + Ceramic Ball Bearing + Titanium Turbine + ada speed sensor utk Compressor wheel-nya
:e-clap:
billyd1773dz
Turboman wrote:Twin scroll sama aja ama Turbo biasa tapi port jalur masuk exhaust dr header-nya ada 2, jadi Turbine housing-nya menjadi perpanjangan header.......
itu aja sih intinya
:e-clap:
yup.... itu basicny twinscroll juga kan.... wkwkwwk :D perkembangannya pasti uda banyak kya yg om turbo bilang :D
twinscroll uda mulai dari taun 89 sih jaman mazda rx7 bwat dual rotor wangkel nya.
memang turbo biasa engga ada variable fin/nozzle yg gerak kya vgt... :D dia manfaatin n maksimalin karakter pulse dri tiap cyld energi bwat muterin turbine lebih besar dan stabil, dan efekny memungkinkan durasi valve overlap VVT bisa lebih lama di banding turbo biasa.
jd tetep aja benefitnya jelas dibanding turbo conventional.
madcat015 wrote:Nubie menyimak trit penuh gizi...
hehe.. lebih simple sebenernya.....
jalurnya aja yg dipisah antar header dri cyld 1-4 dan 2-3 biar g saling interferensi saat vakum... utk engine ber firing order 1-3-4-2
thx
:beer:
Image Billyd1773dz
jadi tambah tau tentang turbo.....
Post by y_anjasrana »
pussiiingg.......
Pelajaran ttg Turbocharger dimulai
Mitsubishi TD-04
Mantap neh (Keongnya)
Nubie menyimak dengan baik dan penuh perhatian... :ungg:
Turbo yg mulus... errr... maksud ane... unggg... bagus. :ungg:
Felixz_Yaris
Post by Felixz_Yaris »
*nubie juga ikut menyimak*
Btw turbonya :cupss: bening, alus, mulus, lembut, lumerrr..
:ngacir: :ngacir:
[TYCI 917]
[YKC]
ini yg disebut turbomama ya om?
makin tertarik dengan pelajaran turbo
