Sleeper Car
Felixz_Yaris
Sleeper Car
Post by Felixz_Yaris »
iseng iseng bikin trit..
mobil sleeper disini mobil yg ext nya keliatan std abis tapi performanya gila ...
mobil sleeper yg perna ente tau..
kl ane yaris item anak motkom. http://www.modifikasi.com/showthread.ph ... ty-sleeper
speknya
Engine:
-PNP and 3angle valve job by FIRNAPROTECHNIK
-greddy turbocharge TD-25
-greddy oil cooler kit
-greddy oil catch tank
-greddy intercooler
-open air filter ARC
-custom aluminium turbo piping
-bottom end low comp CP piston
-custom intake manifold
-custom turbo manifold
-custom downpipe
-pauter i beam chromoly forged
-800cc extra injector
-ACT extreme clutch
-exhaust wrap dei
-billion radiator hose
-NGK iriway 7 sparkplug
-custom teflon engine mounting
-NST waterpump pulley
-NST alternator pilley
-full exhaust piping 2,5inch
-muffler tanabe titanium
-dastek type Q+turbo module
-power enterprice fuel pump 255L/H
-liqui molly 5/50 mollygen oil
-M7 oil filter
and another innova om hen viewtopic.php?f=42&t=21234
:frm_salut: :frm_salut: :frm_salut:
- Ecushop Monster max with SVC controller + dastek q+ with throttle module
- Turbo borgwarner, max boost : 2.5 bar
- injector stage 2 bosch
- Custom Intercooler kit by REV
- Water Methanol Injection Stage 2
- Custom camshaft ex only, made in thai
- EGR deletion kit made in thai
- Fuel Pressure regurator AEM
- Custom surge tank made in thai
- Fuel pump bosch
RESULT : 388HP/700NM oh myyy :big_slap:
- zero to 100kmh in around 5 sec
- 402 m in 12.901
- 201m N/A
rem :
- motul dot 5.1
- rs pro brainded steel brake line
- kevlar merah brake pd
gearbox :
- standard automatic gearbox upgrade with transgo kit
- atf cooler
- fuel cooler
exhaust system
- downpipe kansai
- custom stainless steel pipe 2.5"
- custom muffer
- custom stainless steel muffler tip 3"
mungkin kwn2 ada yg tau lainnya?
[TYCI 917]
[YKC]
Re: Sleeper Car
ngga da yang ngalahin sleepernya Innova D-4D dong..... :big_weee:
:ngacir: :ngacir: :ngacir:
Mazda8 juga sleeper kok.... :big_weee: di jalan dikira Ertiga
Felixz_Yaris
Re: Sleeper Car
ChZ wrote:ngga da yang ngalahin sleepernya Innova D-4D dong..... :big_weee:
yep... sleeper abis... :big_slap:
kl uda bangun, ncus ncus terdengar
[TYCI 917]
[YKC]
liep
Re: Sleeper Car
Post by liep »
mungkin bisa dsertakan total dc utk modif masing2 sleeper car tsb om? spy org awam kyk ane ad pandangan+nambah ilmu...trims
FRD
Re: Sleeper Car
Post by FRD »
innova pipitiai sleeper juga kok :big_smoking:
Felixz_Yaris
Re: Sleeper Car
liep wrote:mungkin bisa dsertakan total dc utk modif masing2 sleeper car tsb om? spy org awam kyk ane ad pandangan+nambah ilmu...trims
wah saya krg paham.. ga ada di tritnya. :big_slap:
[TYCI 917]
[YKC]
liep
Re: Sleeper Car
Post by liep »
wakaka sapa tau ad om, jd org ad gambaran klo mo modif sampe sgitu brarti hrs siapin brp dc, krn g murah modif bgituan, hehe
htannis
Re: Sleeper Car
Post by htannis »
Felixz_Yaris wrote:
-cut-
RESULT : 320HP/630NM
- zero to 100kmh in 6sec
- 402m in 14.58sec
- 201m in 8.91sec
-cut
sorry revisi bentar
itu spek dah lama banget soalnya
- zero to 100kmh in around 5s
- 402 m in 12.901s
- 201m N/A
:big_childish:
well it is, but who cares
htannis
Re: Sleeper Car
Post by htannis »
total bisa lebih dari 1/2 harga mobil baru nya om :big_slap:
Felixz_Yaris
Re: Sleeper Car
kasi gambaran aja bbrp... :mky_01:
open air 1,5 jt keatas
replacement huri 700 rb, knn 900 rb keatas
dastek q 5 jt, q+ 5,5 jt
tune up, dyno 1 jeteng lebih
knalpot full dr header-muffler kira2 2-3 jt
cmiww
[TYCI 917]
[YKC]
liep
Re: Sleeper Car
Post by liep »
wakkk naik ipah seharga fortie ya om htan....klo bkn hobi bgt, don't try this at home, bisa kekunci pintu rmh dr dlm, hehe
htannis
Re: Sleeper Car
Post by htannis »
lebih mahal drpd fortie malahan om :wkkk:
lagi ngerem skrg dah gak mau diapa2in lagi nih, lagi bokek juga :wkkk:
Felixz_Yaris
Re: Sleeper Car
another sleeper very sleeper
http://www.modifikasi.com/showthread.ph ... bo-221-3HP
enjin bay
extnya makk.. sleeperr :big_slap:
- ZAGE Bolt on Turbo Kit
- Turbosmart Ultra-Gate External Wastegate 38mm
- HKS Blow off Valve SSQV4
- PRECISION 440cc Extra Injector
- MOLNAR H-Beam Connecting Rods
- de Auto Motorsport Signature Turbo Design Porting & Polished
- WEAPON-R Intake Manifold
- NGK Iridium BKR7EIX
- DEI Titanium Exhaust Wrap
- B&M Hi-Tek ATF Cooler Kit with 7inch Fan
- JR PROJECT Oil Cooler Kit
- SNOW PERFORMANCE Water Methanol Injection Kit
- APEXi Radiator Cap
- CUSTOM Turbo Exhaust System
- VIBRANT UltraQuite Center Resonator
- Vibrant Flat Black Universal Muffler 2.50"
- PIVOT 3 Drive Flat Throttle Controller
- DEFI Racer Gauge Boost Gauge Meter 52mm
- DEFI Racer Gauge Exhaust Gas Temperature Gauge Meter 52mm
- DEFI Racer Gauge Water Temperature Gauge Meter 52mm
- DASTEK Unichip Type Q+
- DASTEK Turbo Module
turbo makkk..
Dyno at RS Tuning :
Boost : 0,8 Bar Pertamax Plus + WMI
Engine Power : 221.3 HP @6000 RPM
Engine Torque : 277.8 Nm @5000 RPM
[TYCI 917]
[YKC]
htannis
Re: Sleeper Car
Post by htannis »
ini juga sleeper car
innova d4d a/t type v 2010
hasil dyno : 460HP boost 45 psi
on street : sekitar 550HP/1000NM boost 50 psi
quarter miles time : 12.3s Belum maximal masih status coba2
Re: Sleeper Car
Yang lain yang lain, masa melulu yaris innova :ngacir:
octafiantos
Daily Vehicle: xebushanoi-18
Re: Sleeper Car
Post by octafiantos »
Ada beberapa sleeper yang saya kenal langsung. Pertama dua ekor BMW E36, aslinya M52B25 swap jeroan B30, jadi 3000cc dengan Dastek, custom intake-tail dan upgrade sistem pengereman.
Kedua E30 swap ke 1UZ-FE, V8 4000cc milik temen kuliah. Ini yang saya angkat topi, karena seperti Mike Burroughs/Stanceworks. Semua dikerjakan sendiri di hari libur di luar nganter anak jalan jalan. Dari idupin mesin dari junkyard, ukur mounting, pasang transmisi, welding, bikin cooling system, ngurut wiring semua dikerjain sendiri. Yang disub con intake-knalpot. Udah hampir setahun, masih persiapan roll out. Sedang upgrade braking system dan dashboard. Sementara hanya ini pr untuk rolling. Mesin sudah nyala dengan cooling sistemnya, elektrik udah nyala, belum ada AC. Dan ga speed freak amat, cuman gila aja pingin bikin E30 V8.
Iphone 9.5 Pake Tapatalk.
Felixz_Yaris
Re: Sleeper Car
htannis wrote:ini juga sleeper car
spek list upgrade nya om?
:ungg:
[TYCI 917]
[YKC]
htannis
Re: Sleeper Car
Post by htannis »
:ungg:
spec engine :
- ecushop monsmax with svc contoller tandem with dastek q
- gizmo boost controller
- 1kd 3000cc d4d diesel engine
- turbo te06 boost max 60 psi
- custom manifold and downpipe made in thailand
udah segitu aja udah ada bayangan kan :ngacir: :ngacir: :ngacir:
Felixz_Yaris
Re: Sleeper Car
:ungg:
spec engine :
mak :big_chicken:
err iya iya um...
bntr itu swap enjin ? :e-think:
[TYCI 917]
[YKC]
FRD
Re: Sleeper Car
Post by FRD »
amfibi wrote:Yang lain yang lain, masa melulu yaris innova :ngacir:
:mky_03: :mky_03: :mky_03:
Sent from my HM NOTE 1W using Tapatalk
Re: Sleeper Car
RB1 punya temen ane di jakarta bagus tuh, velgnya bagus juga...
Apalagi RB1 juga bagus buat sleeper car
Sent from Nokia 1100 4G LTE-A
htannis
Re: Sleeper Car
Post by htannis »
Felixz_Yaris wrote: mak :big_chicken:
err iya iya um...
iyo dah swap engine ke 1kd 3000cc
kalau turbo gede di 2kd 2500cc udah gak ngangkat lagi
Felixz_Yaris
Re: Sleeper Car
err iya iya um...
ngerik ngerik...
:ngacir: :ngacir:
[TYCI 917]
[YKC]
Re: Sleeper Car
octafiantos wrote:Ada beberapa sleeper yang saya kenal langsung. Pertama dua ekor BMW E36, aslinya M52B25 swap jeroan B30, jadi 3000cc dengan Dastek, custom intake-tail dan upgrade sistem pengereman.
Beli mesin 1UZ abis berapa duit ya? :big_childish:
ecco
Re: Sleeper Car
Post by ecco »
Mainan warga SM dengan uang berlebih...MANTAAAABBBBBBS
