Mitsubishi R5
Mitsubishi R5
Post by y_anjasrana »
Introducing......................
The Mitsubishi R5.... :mky_02: :mky_02: :mky_02:
Based on the new Mirage road car, which is called Space Star in some countries, the rally car has been designed and developed by Tomas Weng of Mpart AB (Ralliart Sweden) and could be seen in WRC 2 next season.
Fitted with a 1620cc version of the engine that appeared in the Evo X, it features a five-speed Sadev transmission and four-wheel-drive. It has MacPherson suspension all-round, mated to specially designed sub-frames and Öhlins dampers.
TECHNICAL SPECIFICATION
Engine :4 cylinder, 16 valve transverse 1620cc, Garrett turbo with 32mm restrictor Gems ECU
Power / Torque : 280hp@7500rpm, 450Nm@7500rpm
Transmission : Sadev 5-speed sequential, Mechanical differential front and rear with AP coupling
Suspension : MacPherson strut all round, Ohlins dampers, Docal sub-frames
Brakes : AP 4-pot front and rear, ventilated discs, Asphalt 355mm, Gravel / snow 300mm
Wheels : Asphalt: 18 x 8in, Gravel: 15 x 7in, Snow: 16 x 5in
Dimensions : Length: 3740mm
Width : 1820mm
Height: 1490mm
Wheelbase : 2470mm
Weight: 1230kg
http://www.wrc.com/en/wrc/news/septembe ... 2-12-.html
Kayaknya sering liat.......... :big_think: :big_think: :big_think:
Re: Mitsubishi R5
hmm... agak bingung baca beritanya. evo X kan gak pake mesin 1.6L, tapi 2.0L..
trus masa torque max di 7500RPM juga...
apa pun itu, kereeeen euy mirage diginiin... :big_exellent:
speedfreak
Re: Mitsubishi R5
Post by speedfreak »
nah gini dong kalau bikin mobil reli kan terlihat agak niat dan kerenan dikit..
beberapa hari lalu liat di situs online berita tentang adanya mitsubishi mirage challenge 2015 dan ada bengkel tuner yang menawarkan mobil mitsu mirage yang sudah disetting rally..
quote :
Jakarta -Pereli nasional, Subhan Aksa bersama timnya, Firna Bosowa Rally Team (FBRT) menawarkan paket balap reli dengan menggunakan Mitsubishi Mirage untuk pebalap pemula. Paket itu ditawarkan dengan total harga Rp 485 juta.
Dana itu dialokasikan untuk membeli satu Mirage yang sudah disetel untuk reli dan operasional event balap. Satu mobil Mirage yang siap berlaga di balap reli dibanderol Rp 295 juta dan operasional event sebesar Rp 190 juta untuk 6 seri balap dalam satu tahun.
Mirage yang disetel untuk ajang balap ini pun disiapkan untuk mengikuti kejuaraan nasional Rally, Sprint Rally dan Balap Nasional (touring car). Mirage yang disetel itu pun cocok untuk medan pada ketiga kejuaraan tersebut.
"Dalam hal ini kita menyediakan mobil kita yang bisa dipakai di gravel dan aspal," kata Tim Director FBRT Sports Mago Sarwono di Jakarta, Jumat (30/1/2015).
Namun, untuk mengikuti ajang balapan itu, Mirage terbaru mendapat sedikit perubahan. Dari segi eksterior Mirage ini mendapatkan Sump Guard, Mud Flaps, Rims for Rally 5 pieces, Rims for Touring 5 pieces, Tarmac Tires 5 pieces, dan Bonnet pin.
Beralih ke sisi interior, Mirage yang siap beradu di lintasan balap itu mendapatkan rollcage, Bucket Seat, Safety Belt, Foot Rest and Navigator, Steering Wheel.
Sementara di balik kapnya FBRT menghadirkan Racing Clutch Piggybag, optional berupa Brake Line, Radiator Hoise dan Oil & Radiator Cap.
Mirage ini pun mendapatkan perlengkapan lain berupa Handbrake Hydraulic, MCA Dumper for Rally, Aragosta Dumper for Tarmac, serta Fire Extinguisher (4kg). Dengan begitu, Mirage yang digarap FBRT siap berlaga di ajang Kejuaraan Nasional Rally, Sprint Rally dan Balap Mobil (touring car).
unquote.
kalau dilihat penjelasan di atas, sepertinya hanya kosmetiknya dan aksesori saja sedangkan tidak disebutkan perubahan di sisi mesin dan settingan kaki-kaki (tapi bukan velg dan bannya ya).
b8099ok
Re: Mitsubishi R5
Post by b8099ok »
Shock aragosta bikin ngiler,...
FWD + RWD + 4WD = :big_cat:
WalkingStone
Re: Mitsubishi R5
Post by WalkingStone »
mirage reli ini kayaknya udah di review ama aut*b*ild bukan?
billyd1773dz
Re: Mitsubishi R5
Post by billyd1773dz »
yang R5 guanteng................. technically, evo x goodness on miras cover.......... wkwkwkwk :D
enjinnya memang strip down 4B11T om kopat. :D
klw yg lokal FBRT, modifnya kira2 sampai 150jt. itu bukan aksesoris saja.......... weight reduction nya ngeri, body panel uda fiber/abs semua... bushing di ganti heavy duty dengan reinforce di chassis sana sini dan skidplate di bagian vital, steering rack diganti/di kasih steering reduction macam howe untuk nguragin lock to lock... paket suspensi rally bisa 1/3-2/3nya sendiri hargany. handbrake ganti hidrolis, roll bar dll buanyak modipnya......
enjin n gb yang regulasi di kelasnya harus tuned std.
sama sekali bukan mobil standar.
:beer:
Image Billyd1773dz
lend3
Re: Mitsubishi R5
Post by lend3 »
time to repost koleksi youtube.
speedfreak
Re: Mitsubishi R5
Nah setelah baca info dari master billy baru deh dapat gambaran tentang seberapa sudah dimodifnya itu mirage rally yg dibuat FBRT..
makasi infonya. .
soale saya cuma baca berita yg tadi saya paste ke sini itu dan di situ tidak dijelaskan segamblang apa yg dijelaskan master billy.. hehe
Re: Mitsubishi R5
Yupp.... beda kelas antara R5 dgn mirage yg dipakai Subhan. Yg ga kebayang itu body seringan mirage dipasangin mesin 1600cc turbo. Ngerikkkk.....
Makanya di video test di salju, jalannya bisa kenceng bingitts......
Re: Mitsubishi R5
Kelar nonton videonya... Ngiler banget liat mirage rally lokal... :ungg:
Punya duit 300 jt angkut deh nih mobil 1 kalo kebanyakan duit :big_slap:
Re: Mitsubishi R5
Kok mirip mobil saya sih :big_chicken:
Re: Mitsubishi R5
Mirip tp udah beda jeroan om. Mungkin mitsu pgn niru kesuksesan 206 dulu.
Re: Mitsubishi R5
y_anjasrana wrote:Mirip tp udah beda jeroan om. Mungkin mitsu pgn niru kesuksesan 206 dulu.
dan 206 niru lancer... :big_weee:
Re: Mitsubishi R5
206 bukannya lanjutan dr 205 rallye yg termasuk ganas pd masanya ya? Saingan ketat dgn lancia delta.
