Mitsubishi Eclipse Cross 2017
Gilzy
Post by Gilzy »
After numerous spyshots and teaser images, the covers have finally been pulled off the Mitsubishi Eclipse Cross. Yes, you read that right – the name of the diamond brand’s iconic compact two-door has been reused on a crossover, essentially a sportier “coupé” version of the ASX.
Measuring 4,405 mm long, 1,805 mm wide and 1,685 mm tall, the new car is 110 mm longer, 35 mm wider and 60 mm taller than the ASX, although the 2,670 mm wheelbase remains the same.
Although it’s been significantly toned down from the XR-PHEV concepts that previewed it, the Eclipse Cross carries over many of the styling cues. Front and centre is Mitsubishi’s Dynamic Shield grille, flanked by large head- and fog light clusters, while the wedge-shaped profile, steeply-rising beltline, fast rear windscreen rake and short rear overhang give the car a more dynamic look.
The deep character line along the side of the car runs into the tail lights, and emphasises the beefy fender flares. At the rear, the Eclipse Cross’ LED tail lights stretches across the rear windscreen, which is split Honda CR-Z-style. The third brake light is situated along the dividing bar, and when illuminated it connects the tail lights, forming a single beam of light.
The red paint you see on this car is new for Mitsubishi, and features a semi-transparent red coat and a clear coat over the standard base coat to create high colour saturation and intensity, providing what Mitsubishi says is a “highly-refined finish.” Sounds a lot like Mazda’s signature Soul Red Metallic to us.
Step inside and you’ll find an interior that’s actually rather reminiscent of the Lexus NX, with a cliff-like centre console framed by silver metal trim pieces. There’s even a Touchpad Controller that is a direct ripoff of the Lexus’ Remote Touch pad, manipulating the centre display. Speaking of which, the Smartphone Link Display Audio system supports Apple CarPlay and Android Auto.
Ahead of the driver, there’s a head-up display that shows vehicle speed, data from the active safety systems and other necessary information, while at the back, the 60:40 split-folding rear bench slides and reclines.
Power comes from a new 1.5 litre direct-injected turbo petrol engine mated to a CVT, the latter featuring a Sport Mode with eight virtual ratios; there’s also a 2.2 litre turbodiesel paired to an eight-speed automatic transmission. No output figures have been revealed just yet.
Under the skin, the Eclipse Cross features an electronically-controlled all-wheel drive system, as well as Super All-Wheel Control (S-AWC) integrated dynamics control system with brake-activated Active Yaw Control (AYC). A three-point front strut tower brace and rear structural bonding increase body rigidity, which, combined with detail suspension optimisation, is said to offer precise handling and superior stability.
Menarik untuk melihat SUV baru Mitsubishi ini. Apakah ini untuk menggantikan Outlander Sport atau memang berada di kelas di atas model itu. Memiliki bagian belakang yang unik dan desain dashboard yang mirip dengan Lexus NX beserta Touchpadnya. Semoga aja bisa masuk ke Indonesia tahun ini.
adriangaut
Daily Vehicle: 1988 300E MT
Re: Mitsubishi Eclipse Cross 2017
Post by adriangaut »
Kenapa gak jadi outlander sport aja sih ini mobil...kelihatan dari fotonya sih dimensinya mirip"
Malah jadi eclipse...padahal eclipse itu lebih terkenal sebagai mobil sport...
cursQ
Post by cursQ »
Mitsubishi menggunakan nama2 mobil sport jaman dulunya hahaa kaya mirage dulu keren tp skrg apa hehe
efact
Post by efact »
sepertinya ga akan masuk Indonesia dalam waktu dekat oom... sebagai pengganti outlander juga ga mungkin, sebab Outlander sport sendiri kan udh punya model all new nya... tp juga kayanya ga bakalan masuk Indo tahun ini :mky_03:
2011 Hyundai ix35
2001 BMW E39 530i
jetzcar
Daily Vehicle: GE8
Post by jetzcar »
semoga masuk sini dan pakai mivec diesel :mky_03:
LiveInTheFastLane
Post by LiveInTheFastLane »
kayaknya ga bakal masuk indo sih. IMHO, kalo diliat dari model lebih bagus ini daripada outlander which is bisa makan pasarnya outlander, kalo misalkan diatas outlander deket harganya sama PS bisa bisa mobil ini ga laku?
:mky_06: :mky_06: :mky_06:
rajapb
Post by rajapb »
Kayak nya ini emang penerus nya os tapi ganti nama. Btw kenapa harus make nama eclipse sih, bisa2 gto sama evo bakal jadi suv juga nih
belakangnya jelek bgt... keknya emang udah tradisinya mitsu ya, depan dibikin bagus bgt tp belakangnya jelek bgt :mky_07:
anyway velgnya mirip ama CRV pre facelift yg 2.4...
Zaxis
Post by Zaxis »
Kaya nya blom masuk taon ini,mau launching xm dulu
armann
Post by armann »
ohhh interiornya.... poor man's lexus nx :big_slap:
alicevamps
Post by alicevamps »
Nama2 produk mitsubishi itu2 aja ya, bikin bingung kayak eclipse, colt, mirage, bahkan ada lancer disebut galant fortis.
emansipasi perempuan....tapi jangan panggil saya "om"
pau
Post by pau »
Touchpad buat apa? Layarnya (keliatan) kecil gitu.. dan sederhana
Jindanjun
Post by Jindanjun »
Desain belakangnya perlu waktu buat dicerna mata...agak mengingatkan sama pontiac aztek,
tp lama2 sepertinya terbiasa melihatnya...gak kayak kakaknya yg gak selesai2 mata kita mencerna desain belakangnya..
ap kt nt aj
ane lihat ada tombol s-awc? :big_think:
gak bakal masuk sini kalo iya... :mky_07:
racho
Daily Vehicle: Kawa EX650E
Post by racho »
buritannya bentuknya aneh gitu.
apa mungkin saking fokusnya sama aerodinamika sampai ngorbanin bentuknya?
kalo dari bentuk belakangnya, keliatannya koefisien drag-nya bakal kecil tuh.
mirip2 sama mirage yang konon jadi mobil bensin non-hybrid paling efisien dengan koefisien drag-nya yang cuma 0,27;
tentunya dengan bentuk buritan dan spoiler yang... jelek.
:mky_05:
anrico17
Daily Vehicle: Disetirin
Post by anrico17 »
New outlander sport????
coba bayangin Mitsu bikin SUV namanya lancer... trus yang evolution hybrid....
bakal parah si fanboy mitsu pd komplen, termasuk gw....
L15Z6, 4N15
Venturtle
Post by Venturtle »
semoga masuk sini.. :mky_02: :mky_02:
Peace of mind.
Pboyz97
Post by Pboyz97 »
Mirip OS bentuk & dimensinya
'12 Avanza K3VE
'24 U11
'12 GNKI 2KD
cursQ
Post by cursQ »
Beneran masuk sini kah?? Cakap kali ini
michaelgiri93
Post by michaelgiri93 »
cursQ wrote: Fri Mar 10, 2017 2:22 Image
Manual 6 speed? Ntabz :big_love:
'98 new galant st black -5 mt
adrevolution
Daily Vehicle: Mazda 2
Post by adrevolution »
Pilihan mesinnya sptnya menarik. Yg bensin kayaknya mesin all-new karena selama ini mitsu belom pernah ngeluarin mesin 1500cc turbo. Yg diesel juga kayaknya masih turunan mesin ANPS (semoga yg ini masuk karena udah terbukti oke di ANPS).
Michaelktp
Post by Michaelktp »
anrico17 wrote: Fri Mar 03, 2017 8:44 New outlander sport????
Bisa jadi memang penerus OS, secara nyaris impossible kalau Eclipse Cross ditaruh diantara Outlander dan Outlander Sport. Segmennya terlalu mepet.
Manufaktur yang memakai nama produk-produk legendarisnya dengan harapan konsumen akan selalu ingat dengan masa kejayaannya produknya itu. Hmmm.... kalau tidak mau membuat generasi penerusnya, better itu nama dipensiunkan saja lha. Jangan ditambahin embel embel Sport atau Cross segala. #gagalpaham
Michaelktp
Tampang LMPV XM versi produksi sudah terlihat pada CUV Eclipse Cross (EC) ini. Head lamp sipit tajam dengan fog lamp besar, sebenarnya kurang sinkron dan lebih bagusan tampang ANPS yang head dan fog lampnya terlihat sinkron. But overall is OK. Semoga buritan LMPV XM akan lebih bagus dari CUV EC & ANPS dan menjadi mobil Mitsu yang tidak menimbulkan kontroversi design buritannya. Selain tampang, kemungkinan besar misteri mesin bensin yang akan diusung oleh LMPV Mitsu XM nantinya juga sudah terlihat mengingat statement PT. KTB bahwa XM adalah LMPV dengan platform CUV dan mesin all new 1.5L. Hehehe sorry OOT
Mesin 1.5L Turbo
In my opinion kemungkinan besar mesin non Turbo LMPV XM versi produksi di Q3
Mesin 2.2 D Turbo
Menarik sekali pilihan mesin Eclipse Cross ini karena untuk tipe bensin:1.5L MIVEC Turbo. Penasaran pada spesifikasinya secara selama ini tidak ada displacement 1.5L di line up MIVEC petrol dan diesel engine. Yang ada selama ini hanya 4G15 yang dipakai Colt T120SS sejak jaman baheula. Displacement 1.5L jika masuk Indo akan lebih menarik di mata konsumen secara sudah sejajar dengan Honda HR-V sebagai market leader entry-level SUV. Jadi Eclipse Cross tidak masuk segmen nanggung dan terlalu berdekatan dengan mid SUV monocoque trim terendah (2.0L M/T) seperti OS di Indo saat ini. Positifnya juga bisa sharing mesin dengan LMPV XM versi produksi karena tampang mereka kemungkinan besar seperti pinang dibelah dua. Seperti pada Nissan GL-Juke (HR15DE) dan Honda HRV-Mobilio (L15Z1). Konon segera menyusul Toyota CHR-Yaris (1NZ-FE). Tinggal strategi PT. KTB pretelin saja Turbo di mesin 1.5L dan pasang M/T jika ingin harga yang lebih bersahabat untuk CUV EC seperti pada LMPV XM nanti...hahaha. Pasti langsung jadi pilihan menarik lha.
In my opinion untuk mesin dieselnya kemungkinan kecil bisa masuk ke Indo sini mengingat ini adalah entry level SUV. Jika memasang diesel harga akan menjadi mahal dan kembali berdekatan dengan medium SUV.
limaues
Post by limaues »
Sayang belakang nya perlu di biasakan liat nya..
Atau mungkin Mitsubishi bisa pake strategy nya Kia yg bajak orang design dari product lain...
racho
Post by racho »
Michaelktp wrote: Wed Mar 15, 2017 15:23 Menarik sekali pilihan mesin Eclipse Cross ini karena untuk tipe bensin:1.5L MIVEC Turbo. Penasaran pada spesifikasinya secara selama ini tidak ada displacement 1.5L di line up MIVEC petrol dan diesel engine. Yang ada selama ini hanya 4G15 yang dipakai Colt T120SS sejak jaman baheula. Displacement 1.5L jika masuk Indo akan lebih menarik di mata konsumen secara sudah sejajar dengan Honda HR-V sebagai market leader entry-level SUV. Jadi Eclipse Cross tidak masuk segmen nanggung dan terlalu berdekatan dengan mid SUV monocoque trim terendah (2.0L M/T) seperti OS di Indo saat ini. Positifnya juga bisa sharing mesin dengan LMPV XM versi produksi karena tampang mereka kemungkinan besar seperti pinang dibelah dua. Seperti pada Nissan GL-Juke (HR15DE) dan Honda HRV-Mobilio (L15Z1). Konon segera menyusul Toyota CHR-Yaris (1NZ-FE). Tinggal strategi PT. KTB pretelin saja Turbo di mesin 1.5L dan pasang M/T jika ingin harga yang lebih bersahabat untuk CUV EC seperti pada LMPV XM nanti...hahaha. Pasti langsung jadi pilihan menarik lha.
semoga saja Eclipse Cross masuk sini pakai 1,5L MIVEC Turbo dan XM dikasih mesin yang sama tapi tanpa turbo.
begitu udah rilis, tinggal beli XM, pasangi turbonya Eclipse n pigibek...
cuss cuss dahh...
:mky_02:
[thepowerofwetdreams]
