Performance
Acceleration: 0-100 km/h (0–62 mph) under 3.5 seconds
Top speed: 390 km/h (240 mph)
Standing quartermile: 10 seconds, end speed 217 km/h (135 mph)
Braking distance: 32 m (100–0 km/h)
Body
Two-door, two-seater with removable hardtop stowable under the front boot lid.
The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foamsandwich reinforcements.
Dimensions
Ground clearance: 100 mm (3.9 inch)
Fuel capacity: 80 litres (17.6 gallons)
Luggage compartment: 120 litres (26.4 gallons)
Dry weight: 1175 kg
Areodynamics
Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis.Venturi tunnels at the rear of chassis/body.
Chassis
Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
Front and rear suspension: Double wishbones, adjustable Öhlins Racing gas-hydraulic shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
Brakes
Front brakes: Ventilated discs Ø 340 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
Rear brakes: Ventilated discs Ø 315 mm, 28 mm wide. 4 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
Wheels
Koenigsegg magnesium alloy wheels with centre locking.
Front: 18†x 9,0â€Â.
Rear: 20†x 12,5â€Â.
Tyres
Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
Front: 255/40 ZR 18
Rear: 335/30 ZR 20
Steering
Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres.
Engine
Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
Displacement: 4.700 cm3.
Compression: 8.6:1
Weight: 210 kg
Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
Oil: SAE 10W60 fully synthetic racing.
Oil tank capacity: 12 litres (2.64 gallons)
Induction system: Sequential, multipoint fuel injection. Supercharging with 1.0 bar boost pressure. Intercooler.
Fuel: 98 RON unleaded.
Ignition system: Direct coil on plug. Transistorised.
Power output: 655 bhp at 6.800 rpm.
Maximum torque: 750 Nm (550 ftlb) at 5.000 rpm.
Maximum rpm: 7.300 rpm.
Transmission
Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.
Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch).
Equipment
In standard mode the car is very well equipped with many items that competitors have as options. Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.
Standard equipment
Removable roof panel
Climate control
Electric rear mirrors
Leather interior
Central locking
Electrical windows
Alarm with immobilizer
Toolkit
Driver side airbag
Power steering
Hydraulic ride height control
Servo assisted brakes
ABS
Traction control
Stereo with CD-player
Customer options
Custom Color Leather Interior
Custom Paint Color
Parking Sensors
GPS Navigation
Sequentially operated gearbox
Rearview Camera
Fitted Luggage
Koenigsegg reserves the right to change or amend this information without notice.
Koenigsegg CC8S
Koenigsegg CC8S
