Performance
Acceleration: 0-100 km/h (0–62 mph) 3.2 seconds
Top speed: 395+ km/h (242+ mph)
Standing quartermile: 9 seconds, end speed 235 km/h (146 mph)
Braking distance: 31 m (100–0 km/h)
Lateral g-force: 1.3 g
Fuel consumption: Highway travel: 13 l/100 km
Combined: 17 l/100 km
Body
Two-door, two-seater with removable hardtop stowable under the front boot lid.The body is made of preimpregnated carbonfibre/kevlar and lightweight hard-foam sandwich reinforcements.
Dimensions
Ground clearance: 100 mm (3.9 inch)
Fuel capacity: 80 litres (17.6 gallons)
Luggage compartment: 120 litres (26.4 gallons)
Dry weight: 1180 kg
Areodynamics
Cd. 0.297. Frontal area 1.825 m2. Completely flat underside of chassis.Venturi tunnels at the rear of chassis/body.
Chassis
Semi monocoque made of preimpregnated carbonfibre and with honeycomb reinforcements for added stiffness.
Front and rear suspension: Double wishbones, adjustable VPS custom racing shock absorbers, pushrod operated. Anti-roll bar. Electronically adjustable ride height.
Brakes
Front brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
Rear brakes: Ventilated discs Ø 362 mm, 32 mm wide. 6 piston light alloy calipers. Power assisted. Koenigsegg Advanced Control system.
Wheels
Koenigsegg magnesium alloy wheels with centre locking.
Front: 19†x 9.5â€Â
Rear: 20†x 12.5â€Â
Tyres
Michelin Pilot Sport 2. Unidirectional with asymmetric tread pattern.
Front: 255/35–19†(Y)
Rear: 335/30–20†(Y)
Steering
Rack and pinion power assisted steering. 2.7 turns lock to lock. Turning circle: 11 metres
Engine
Type: V8 cast aluminium, 4 valves per cylinder, double overhead camshafts. Cam cover of carbonfibre.
Displacement: 4.700 cm3.
Compression: 8.6:1
Weight: 215 kg
Lubrication system: Dry sump with unique oil spray piston cooling. Oil cooler.
Oil: SAE 10W60 fully synthetic racing.
Oil tank capacity: 12 litres (2.64 gallons)
Induction system: Sequential, multipoint fuel injection. Dual Rotrex centrifugal compressors with 1.4 max boost pressure. Intercooler.
Fuel: 98 RON unleaded.
Ignition system: Direct coil on plug. Transistorised.
Power output: 806 bhp at 6.900 rpm.
Maximum torque: 920 Nm (678 ftlb) at 5.700 rpm.
Maximum rpm: 7.600 rpm.
Transmission
Specially developed 6-speed gearbox by Cima. Incorporated internal oil pump and oil cooler. Torque sensitive, limited slip differential.
Clutch: Dual Plate, organic or cintered Ø 215 mm (8.46 inch). Oil-cooled and electronically operated.
Equipment
In standard mode the car is very well equipped with many items that competitors have as options. Many customers, however, want to further equip the car. Therefore we can offer a list of customer options which should fulfil every demand.
Standard equipment
Detachable roof panel
Climate control
Electric rear view mirrors
Leather interior
Central locking
Electrical windows
Alarm with immobilizer
Driver side airbag
Power steering
Hydraulic ride height control
Servo assisted brakes
ABS
Traction control
Stereo with CD-player
Tyre pressure sensors
Car cover
Customer options
Custom Color Leather Interior
Custom Paint Color
Parking Sensors
GPS Navigation
Sequentially operated gearbox
Rearview Camera
Fitted Luggage
Koenigsegg reserves the right to change or amend this information without notice.
[b]Koenigsegg CCR[/b]
