Gassss, jajanan wajib nih kalo pas ke luar kota, heheSuryaputra wrote: ↑Thu May 05, 2022 5:25Tuang aja:whitehorse4 wrote: ↑Thu May 05, 2022 5:22 Sorry oot dikit.. Kebetulan abis ganti oli epro green usia mobil 20 tahun, kalo ditambah semprot pake carb cleaner bakal ngaruh ga ya balikin tenaga yang ilang om? selama ini cuma tune up hasilnya ya gitu2 aja sama aja rasanya
- Redline CFSC 1/2 botol per 30-liter BBM
https://tokopedia.link/ykodqwt4Lpb
Terus tuang dosis maintenis 3-ml per 1-liter pertamax.
- Daily Vehicle: Nissan X-Trail T31 CVT
gak asik belum beli,lagi nunggu promo,Suryaputra wrote: ↑Thu May 05, 2022 3:56Asik dong
Gas polllsss..
Awal ETLE
mau ane buang tuh oli yg super klo dapat q8 promo,
ane keker trs nih,selagi msh tebal amplop THR
wahh ngeri gaspollll ada e tle,
skrg panteng 100-120,ky kereta wisata liat aspal
Etle kan jarang² om , nyolong dikit² cincaivanosz wrote: ↑Fri May 06, 2022 3:21gak asik belum beli,lagi nunggu promo,
IG: @sahabatq8
wah ini ky saran teman ane nih,
tapi ane taat aturan,kuat imin,
tetap panteng 100-120,
aliran sepoi sepoi aja,
btw...
senin depan 8800 promo 180 ribu ya gans,
ane tunggu scepatnya gans,
btw...
- Daily Vehicle: Fortuner gerobak
wadaw kapan nih ft8800 180 rebu per liter wkwkwk ikut beli ah kalo segitu mahvanosz wrote:wah ini ky saran teman ane nih,
btw...
pecinta bio solar
https://tokopedia.link/HP5y5II2Npbctopher7 wrote: ↑Fri May 06, 2022 6:34wadaw kapan nih ft8800 180 rebu per liter wkwkwk ikut beli ah kalo segitu mahvanosz wrote:wah ini ky saran teman ane nih,
btw...
https://tokopedia.link/kVK7QfN2Npb
Kalo oli repsol gxr platinum 5w30 pake smpe brp kilo ya om?
5rb km max
Or 6 bulan cukup.
Baikla om..
Tp mundurin dikit ke 6rb km (6 bulan) gpp kli ya
yoi gans,ctopher7 wrote: ↑Fri May 06, 2022 6:34wadaw kapan nih ft8800 180 rebu per liter wkwkwk ikut beli ah kalo segitu mahvanosz wrote:wah ini ky saran teman ane nih,
btw...
8700 aja mantap apalg terbaru,
sikatttttttt gans,
klo promo
wahhh oli sultan beli di resmi aja,Suryaputra wrote: ↑Fri May 06, 2022 10:01https://tokopedia.link/HP5y5II2Npbctopher7 wrote: ↑Fri May 06, 2022 6:34wadaw kapan nih ft8800 180 rebu per liter wkwkwk ikut beli ah kalo segitu mahvanosz wrote:wah ini ky saran teman ane nih,
btw...
apalg nunggu promo nih,
mudahan gak lama,THR amplop masih tebal nih,
belum habis buat sepoi sepoi msh tutup suasana libur,
kok tokonya ga keliatan meyakinkan ya omSuryaputra wrote:https://tokopedia.link/HP5y5II2Npbctopher7 wrote: ↑Fri May 06, 2022 6:34wadaw kapan nih ft8800 180 rebu per liter wkwkwk ikut beli ah kalo segitu mahvanosz wrote:wah ini ky saran teman ane nih,
btw...
pecinta bio solar
tapi yang panda auto oke sih harusnya, tapi masih libur yak wkwkctopher7 wrote:kok tokonya ga keliatan meyakinkan ya om
pecinta bio solar
- Daily Vehicle: Ford Ecosport TiVCT DP6S
Om2 semua mis. Turboman dsan expert2 lainnya maaf mau tanya
Isenf kelilimg bitog cari 913D, apakah kesimpulan di bawah trpat? Tp beberapa kali pake 5w40 tarikan mobil jadi berat, plus API SL yg sdh jarang atau skg banyakannya semi synth. Kepikiran nyoba Motul Multigrade 10w30 Dturbo buat 6 bln aja di Duratec TiVCT 1.5
Ford 913-D is based on ACEA A5/B5 then Ford add a few other requirements - It needs to be a 5W30 oil - at the thin end of the viscosity grade for better fuel economy - have an increased TBN (from min 8 to min 10) for a longer oil change interval - it needs to have extra ZDDP (about 1000 ppm zinc) for extra wear protection - pass some extra seal compatibility tests The extra ZDDP (for cam chain wear I believe) means the oil is API SL rather than SN. If you can't get a 913-D oil you have two options, first just get a good quality 5W30 A5/B5 oil, or second get a good quality 0W40 (or 0W30 or 5W40) that is A3/B4 and some OEM like MB 229.5, BMW LL-01 or Porsche A40 as these also most likely have a TBN of 10 and 1000 ppm zinc. Two options are follow the viscosity (5W30 A5/B5) or follow the add pack (0W40 A3/B4). Can't do both without the rare 913-D oil. I would go the 0W40 with OEMs myself.
Panda auto, konon menurut warga SM yg pernah order, itu dikirim dr Sunda Motor bandung.
Jl. Sunda No.26, Kb. Pisang, Kec. Sumur Bandung, Kota Bandung, Jawa Barat 40112
(022) 4235616 https://g.co/kgs/FTdUQT
Dengan plang segede itu, sgt kecil kemungkinan palsu
Tp klo ditanya sellernya, mereka gak admit adalah sunda motor.
Ya krn policynya spt itu respect ajah wkwkwkw.
Pilihan masing2 ajah mbah.
Klo saya pribadi.. 4rb km ganti, local blend dan harga ekonomis, gak berani itung2an sm mesin
Sy pakai PFG 0w20 aja, ganti di 4rb km, krn hi rpm suara mesinnya beda banget, itu klo UOA, bs jadi dah masuk visco W16 kayanya
- Daily Vehicle: Delman
Kalau mau 913D 5w30 kan ada motul om. Kalau offline bisa di Toda/Sentra Pelumas. Kalau online kirim2 bisa beli di Sentra Pelumas aja.bensindanoli wrote: ↑Sat May 07, 2022 1:42 Om2 semua mis. Turboman dsan expert2 lainnya maaf mau tanya
Mesin bensin ?bensindanoli wrote:Om2 semua mis. Turboman dsan expert2 lainnya maaf mau tanya
ya pake buntut 40 ya pasti berat lah
pake 5W30 / 0W30 kalo di man book gak rekomen 0W20
- Daily Vehicle: [cencored]
Ini bensin turbo kan?bensindanoli wrote: ↑Sat May 07, 2022 1:42 Om2 semua mis. Turboman dsan expert2 lainnya maaf mau tanya
Kalau dikasi oli Dexos gimana?
yg pertama om mksdnya yang meragukan, yang harganya 175 rebuSuryaputra wrote:Panda auto, konon menurut warga SM yg pernah order, itu dikirim dr Sunda Motor bandung.
pecinta bio solar
Duratec tivct 1.5 bukanya mesin ecosport, turbo bensin tapi 3 cylinder. Aman gak pilih² olisintoni wrote: ↑Sat May 07, 2022 5:52Ini bensin turbo kan?bensindanoli wrote: ↑Sat May 07, 2022 1:42 Om2 semua mis. Turboman dsan expert2 lainnya maaf mau tanya
IG: @sahabatq8
si sentra pelumas jg sama mbahSuryaputra wrote: ↑Sat May 07, 2022 2:34Panda auto, konon menurut warga SM yg pernah order, itu dikirim dr Sunda Motor bandung.
kl di samperin ke toko nya yg di latumenten jg ga mau ngaku..
malu2 kli mreka
trakir nanya ke si ayung bonjer jg ngaku nya ga punya toko onlen, malah ybs nawarin kita orang suru dagang d toko onlen, nanti ngambil ama dia oli nya
Wah godaan iman itu si ayungDOHC wrote: ↑Sat May 07, 2022 10:57si sentra pelumas jg sama mbahSuryaputra wrote: ↑Sat May 07, 2022 2:34Panda auto, konon menurut warga SM yg pernah order, itu dikirim dr Sunda Motor bandung.
malu2 kli mreka
Susah juga ya cari data sheet GXR Platinum di gugel, tapi kalo liat dari range harganya, oli begini disiplin aja max 5000 km / 6 bulan.yanuarra wrote:Baikla om..
Tutup emas kan? Sy lagi pake jg nih baru jalan 800 km, sejauh ini sih mantap.. cuma mesin 3 silinder saya makin berisik hahhaha…tapi tarikan ngacirrr.carlzeiss wrote:Thankyou sarannya om suryaputra dan DOHC, jadinya saya ambil PTT Super synt 0w-20 yg botol kuning
Baru kali ini sih coba yg jenis ini, apakah sudah ada yg pernah pakai ? Dan bagaimana performanya ?
