Honda new Civic Hybrid
conan
Post by conan »
New Civic hybrid :
New Honda Hybrid System with 3-Stage i-VTEC + IMA(Civic Hybrid)
Honda’s independently developed hybrid system, which combines an engine as the primary drive force with electric motor assist to achieve outstanding fuel economy and clean emissions, has evolved significantly. The New Honda Hybrid System features a 3-stage i-VTEC engine that regulates the valves to provide three stages of valve timing (low-rpm, high-rpm, and cylinder idle mode) in accordance with driving conditions, combines with a significantly improved IMA (Integrated Motor Assist) system, to deliver 20% higher output10 along with 5% better fuel economy10 when driven in 10-15 mode. The system provides low-speed torque, on par with a 1.8-liter gasoline engine, while achieving ultra-high fuel economy of 31.0km/l, surpassing Japanese government fuel economy standards for 2010 by 5%. The system also achieves outstanding emissions performance, with emission levels 75% below 2005 Japanese government standards.
A newly developed dynamic regenerative braking system regulates brake assist volume during braking based on the amount of brake regeneration. Whereas a regular brake booster is powered by engine vacuum, this system employs a hydraulic brake booster that utilizes hydraulic pressure stored in the motor to boost braking capacity. This ensures stable braking assist even during Idle Stop, cylinder idle, and at other times when the vehicle is powered by the motor alone, while also allowing total control over the degree of hydraulic braking.
10 Compared to the previous Civic Hybrid
Honda Multimatic S (Civic Hybrid)
The Honda Multimatic S continuously variable transmission delivers smooth, shock-free driving and contributes to improved fuel economy by effectively maintaining the engine in its optimum fuel-efficiency range. Transmission efficiency has been maximized and a wide ratio employed for the high-speed gears, to contribute up to 3.5% increased efficiency during cruising while also delivering more powerful driving performance. At the same time, clutch capacity has been increased to respond to the power unit’s high torque output. All of these improvements have been made while maintaining the same compact design as the previous Civic Hybrid. Finely tuned gearing control responds to driving conditions for a smooth, natural feel.
The Civic Hybrid utilizes motor assist to significantly reduce the load on the engine, achieving ultra-high fuel economy of 28.5km/l for the MX and 31.0km/l for the MXB, which also exceeds Japanese fuel economy standards for 2010 by 5%. The engine also achieves outstanding emissions performance and is recognized by the Japanese government as attaining emission levels 75% below 2005 standards, earning it preferred status under Green Tax program in Japan.
liat2aja
Post by liat2aja »
bung conan kok nyasar postnya?
biar mod yang benerin kali ya...
btw juga ada review Civic Hybrid (baru) di Autobild edisi terakhir
conan
Post by conan »
oops. Moderator, please move this thread to the sedan section, thank you.
