125cc and kicking...
indomi
Post by indomi »
Fellow SMers,
Gue bikin list kecil2an di rumah ttg motor2 racing ber cc 125 yg gue dapet dari bbrp tempat (internet, majalah, bengkel). ada bbrp produk yg OK menurut gue:
1. Rieju RS2 125
2. Aprilia RS 125
3. Honda CBR 125 R
4. Derbi GPR 125 R
5. Cagiva Mito 125
6. Sachs XTC 125
7. Honda NSR 125
Mudah2 bermanfaat dan jgn lupa komentarnya.
Indomi
Note:
1. info ttg power masing2 motor yg belum gue dapet semua. Ntar kalo gue dapet infonya gue update postingannya.
2. Harga dalam CHF (Swiss Franc)
Paling enak migoreng sama sambel abc ;)
indomi
Post by indomi »
Rieju RS2 125
Negara asal: Spanyol
Harga: kira2 5900 CHF
Year: 2006
Displacement: Yamaha 124.00 ccm (7.57 cubic inches)
Engine type: Single cylinder
Stroke: 4
Power: - HP - Kw
Bore x stroke: 54.0 x 54.0 mm (2.1 x 2.1 inches)
Fuel system: Carburettor. Mikuni VM20SS
Starter: Electric & kick
Cooling system: Air
Gearbox: 5-speed
Transmission type
final drive: Chain
Fuel tank: 10.4 litres
Front brakes: Disc
Rear brakes: Disc
indomi
Post by indomi »
Aprilia RS 125
Negara asal: Italia
Harga: 7590 CHF
Year: 2006
Displacement: 124.80 ccm (7.62 cubic inches). Homologated to Euro 2 standards.
Stroke: 2
Power: --
Compression: 12.5:1
Bore x stroke: 54.0 x 54.5 mm (2.1 x 2.1 inches)
Fuel system: Carburettor. Dell’Orto PHBH 28 BD
Ignition: CDI capacitor discharge electronic
Lubrication system: Separate mixing with variable displacement volumetric pump
Cooling system: Liquid
Gearbox: 6-speed
Transmission type
final drive: Chain
Tank: 14 litres (3.5 litre reserve).
indomi
Post by indomi »
Honda CBR 125 R
Negara asal: Jepang
Harga: 4150 CHF
Year: 2006
Displacement: 124.70 ccm (7.61 cubic inches)
Stroke: 4
Power: 13.00 HP (9.5 kW)) @ 10000 RPM
Torque: 10.10 Nm (1.0 kgf-m or 7.4 ft.lbs) @ 8000 RPM
Compression: 11.0:1
Bore x stroke: 58.0 x 47.2 mm (2.3 x 1.9 inches)
Fuel system: Carburettor. 28mm VK-type
Valves per cylinder: 2
Fuel control: SOHC
Ignition: Capacitor Discharge (CDI)
Starter: Electric
Gearbox: 6-speed
Transmission type
final drive: Chain
indomi
Post by indomi »
Derbi GPR 125 R
Harga: 8000 CHF
Year: 2006
Displacement: 124.76 ccm (7.61 cubic inches)
Stroke: 2
Power: --
Compression: 12.5:1
Bore x stroke: 56.0 x 50.7 mm (2.2 x 2.0 inches)
Fuel system: Carburettor. Mikuni 28 mm
Ignition: Electronic C.D.I.
Starter: Electric
Lubrication system: Oil pump
Gearbox: 6-speed
Versi nude nya (sedikit lebih murah)
indomi
Post by indomi »
Cagiva Mito 125
Negara asal: Italia
Harga: 7700 CHF
Year: 2006
Displacement: 124.63 ccm (7.60 cubic inches)
Stroke: 2
Power: --
Compression: 7.4:1
Bore x stroke: 56.0 x 50.6 mm (2.2 x 2.0 inches)
Ignition: CDI
Gearbox: 6-speed
Transmission type
final drive: Chain
indomi
Post by indomi »
Sachs XTC 125
Negara asal: Jerman
Harga: -
Year: 2006
Displacement: 124.00 ccm (7.57 cubic inches)
Engine power: 11 kW (15 HP) at 10.500 rpm
Stroke: 4
Power: --
Valves per cylinder: 4
Fuel control: OHC
Cooling system: Air
Max. permitted total weight: 330 kg
Tank capacity: 20 litre (incl. 3 litre reserve)
Gear box: 5-gear
Weight: 130 kg (curb weight), 144 kg (weight with fuel)
Max. speed: 102 kph
(sorry yg ini rada susah nyari photo nya yg gedean)
indomi
Post by indomi »
Honda NSR 125
Negara asal: Jepang
Harga: 8000 CHF
Year: 2003 (Produksi tidak diteruskan?)
Stroke: 2
Power: 15.00 HP (10.9 kW)) @ 9500 RPM
Torque: 11.70 Nm (1.2 kgf-m or 8.6 ft.lbs) @ 7000 RPM
Gearbox: 6-speed
Transmission type
final drive: Chain
anak_singkong
Post by anak_singkong »
Honda NSR-125 itu yg dipake team Honda di GP-125 yah? sy kurang
perhatian ama GP-250/GP-125..
desuk
Post by desuk »
kok tanggung banget produk keren gini ngeluarin versi 125 cc ya?
kan kalau balapan ma tiger mesin lama, meski tampang baru, mungkin aja kalah.
tampang aja yang sangar, jangan2 dikalahin ma Satria 150 cc juga.
Shogun SP 125 Fans & User
keren...
mpoezz
Post by mpoezz »
Aprilia RS 125 model nya sangar uey
awal_striker
Post by awal_striker »
gw paling suka derbi gpr.... mantep ga kekecilan ga kegedean.... ato Rieju RS2 125 yang 4 tak.... biar ga masalah ama polisi yang rese..... he he hehh
jangan pake lampu belakang putih!!! silau !!
jangan pake lampu jauh terus !!! silau !!
yang paling penting, jangan ga pake lampu!!! berbahaya!!!
indomi
Post by indomi »
awal_striker wrote: ato Rieju RS2 125 yang 4 tak.... biar ga masalah ama polisi yang rese..... he he hehh
emang polisi rese sama motor 2 tak? kalo iya knp?
anak_singkong
motor Rieju itu mirip bgt ama moge CBR yah? apa emang mrk pegang lisensinya Honda ya?
mpoezz
Post by mpoezz »
soalnya motor 2 tak udah hampir dilarang di jawa bos,kalo ngak salah 2008 udah ngak boleh pakai motor 2 tak katanya polusi.
biasalah polisi indo kalo peraturan ngak jelas kan suka cari cari,disitudah celah mereka hahahaha.
indomi
Post by indomi »
@anak singkong: kalo menurut gue Rieju mirip bgt sama Derbi, apa lagi tangki bensinnya.
Inget mocin Happy? nah itu juga mirip Derbi deh kalo menurut gue. Tapi yah gue nggak tau juga sih soalnya belom pernah liat CBR 150
indomi
Post by indomi »
mpoezz wrote: soalnya motor 2 tak udah hampir dilarang di jawa bos,kalo ngak salah 2008 udah ngak boleh pakai motor 2 tak katanya polusi.
Oh iya??? taun 2008? Lah kan ada jutaan motor 2 tak di Indonesia, gimana tuh?
mpoezz
Post by mpoezz »
mungkin hanya tuhan dan pemerintah yang tau nasip nya hahahahaha
anak_singkong
indomi wrote:@anak singkong: kalo menurut gue Rieju mirip bgt sama Derbi, apa lagi tangki bensinnya.
APA?! :shock:
belom pernah lihat CBR-150? emangnya tinggal dimana sih?
su_minson
Post by su_minson »
desuk Posted: Sat Aug 05, 2006 8:47 Post subject:
jangan yang diliat cuman cc-nya doang liat juga jenis karb-nya, rasio giginya, pengapiannya. udah pernah nyoba lawan nsr 125 2-tak ? pake Rx-king dijamin tewas kalo sama-sama standar....
no one's perfect
budzaemon
Post by budzaemon »
bukannya aturannya masalah emisi gas buang aja? lah klo ga boleh gimana tuh nasib Ninja?
klo menurut gw bukannya peraturan ga jelas, tapi polisinya ga ngerti aturannya secara detail, mereka maen pukul rata aja (2 tak tilang..)...
yg gw khawatirkan sekarang aturan knalpot nih, padahal kan ada itung2annya, nanti maen pukul rata aja lagi knalpot racing tilang...
sori jadi out of topik
anak_singkong
su_minson wrote:desuk Posted: Sat Aug 05, 2006 8:47 Post subject:
bener tuh apa yg dibilang sama bung su_minson :e-clap:
