Suzuki akhirnya merilis GSV-R 2004, menggantikan versi 2003 yg amit-amit....
Ini copy-paste dari http://www.motogp.com
Suzuki Racing have released the technical details and first pictures of the radical new 2004 version GSV-R machine they hope will breath life into their flagging MotoGP fortunes. After winning the World Championship in 2000 with Kenny Roberts, the Japanese factory picked up just 43 manufacturers’ points last season with Roberts and John Hopkins on board. The two American riders will again be in the saddle this season and will be looking to turn the following specification into a race winning machine:
ENGINE TYPE – FOUR-STROKE, WATER-COOLED, V4
DISPLACEMENT - 990cc
MAX POWER - 220+ ps @ 14,500+ rpm
VALVE TYPE - DOHC FOUR-VALVE
CARBURATION TYPE - FUEL INJECTION
LUBRICATION SYSTEM - WET SUMP
CLUTCH - DRY MULTI PLATES (BACK TORQUE REDUCE TYPE)
TRANSMISSION – SIX-SPEED CONSTANT MESH
FINAL DRIVE - CHAIN
FRAME TYPE - TWIN SPAR ALUMINUM ALLOY FRAME
SUSPENSION FRONT - INVERTED TYPE TELESCOPIC
SUSPENSION REAR - LINK TYPE
TYRES - BRIDGESTONE
WHEEL FRONT - 16.5 inches
WHEEL REAR - 16.5 inches
BRAKE SYSTEM FRONT - DOUBLE CARBON DISC (CARBON)
BRAKE SYSTEM REAR - SINGLE DISC (STEEL)
OVERALL LENGTH - 2060mm
OVERALL WIDTH - 660mm
OVERALL HEIGHT - 1150mm
WHEELBASE - 1450mm
WEIGHT - 145kg
FUEL TANK - 24L
Apakah motor ini bisa bersaing dgn pabrikan lain? Kita tunggu saja...
SUZUKI GSV-R 2004
Forum rules
SUZUKI GSV-R 2004
Wah.. berat boss... Nomer 1-5 udah dibooking ama rider2 Honda, Ducati dan Yamaha. No way man...
Utk Suzuki mah bisa menang dari Aprilia aja udah sukurr.... Trus terang blom bisa berharap banyak deh dgn Suzuki.
Wong udah bertahun2 ikutan MotoGP koq cuma bikin 1 tim doank. Dimana-mana kalu timnya banyak baru bisa menang. Soalnya riset dari beberapa tim jelas akan membantu pengembangan motor. Kalu cuma 1 tim, otomatis data pengembangan motornya hanya berasal dari 1 sumber saja. Gak heran prestasinya melorot terus....
