Pilihan HU 1Din terbaik (bs CD, MP3, USB) harga <2jt
- SM Affiliate
Minta input dan saran
U/ HU 1Din dg harga dibawah 2jt dg kriteria:
1. 1Din, Bisa CD, MP3 dan USB.
2. Merk apa aja boleh.. yg penting bukan merk antah berantah, suaranya enak, tampilan keren, ga milih2 media (spt: hrs CD ori) dan bandel (durable).
3. Harga dibawah 2jt... lebih murah lebih baik.. value oriented nih gw :smt003
4. Bukan barang 2nd.
Sementara ini ada di otak gw Sony Xplod CDX-GT660US.. yg harganya Rp. 1.8jtan udah dapat USB FlashDisk 512MB.
Features
S-MOSFET Output Power: 52W x 4
24bit DAC
Pre Out X 2
Frontal USB Input
Preset FM18/AM12
RM-X151 Wireless Card Commander (Included)
RM-X114 Wireless Card Commander (Optional)
Spec
Tuner
FM: Tuning Range (MHZ) 87.5-107.9, 87.5-108
MW: Tuning Range (kHZ) 531-1602, 530-1710
FM: Usable Sensitivity (75Ω) (dBf) 9
FM: Intermediate Frequency (MHz) 10.7MHz / 450kHz
FM: Selectivity (400kHz) (dB) 75
FM: S/N Ratio (Stereo) (dB) 67
FM: S/N Ratio (Mono) (dB) 69
FM: Total Harmonic Distortion (1kHz, Stereo) (%) 0.5
FM: Total Harmonic Distortion (1kHz, Mono) (%) 0.3
FM: Channel Separation (dB) 35
FM: Frequency Response (Hz) 30-15k
CD
Digital Filter (fs) 8
D/A Converter (bit) 24
Frequency Response (Hz, dB) 10-20k, +/-1dB
S/N Ratio (dB) 120
General
Pre Out Output Level (V) 2
Pre Out Impedance (ohms) 220
Maximum Output Power (4Ω, 1kHz) (W) 52
Dimensions (WxHxD) (mm) 178 x 50 x 180
Mounting Dimensions (WxHxD) (mm) 182 x 53 x 162
Weight (kg) Approx. 1.3
Apakah ada pilihan lebih baik??
Features
24bit DAC
Pre Out X 2
Frontal USB Input
Preset FM18/AM12
Spec
Tuner
CD
S/N Ratio (dB) 120
General
MONZA-AUTOSPORT.COM
WA: 08129215600
WA: 08129215600
kalau mau sony kelihatannya bagus type CDX-50UI deh
* Introduction Date: 04-Jun-2007
* iPod® Direct Connection
* Integrated iPod® Connecter supplied
* DRIVE-S CD Chassis for Higher Sound Quality
* 4 x 50W S-MOSFET power output
* 4 Codec (MP3/WMA/AAC/ATRAC) CD Playback
* Front USB/Aux-in for Portable Audio Compatible
* Sony-Bus for CD Changer Control
* EQ3 StageII (3 Band Equalizer)
* Rear/Sub Selectable Pre-Amp output
* Blue Key Illumination
* IR Card Remote RM-X151 supplied
* FREE USB CHARGER!!!!
trus kalau mau yang bagus suaranya bisa pakai Clarion bosss type dxz-576 usb
* Siap untuk CD-R/RW
* MP3, WMA dan iTunes® kompatibel dengan AAC serta tampilan ID3-TAG
* Konektor USB depan
* Kapasitas trek maksimum: 65,025 (255 trek dalam 255 folder)
* 18 buah preset stasiun FM, 6 buah preset stasiun AM
* Kemampuan kontrol iPod® menggunakan model EA1276 opsional
* Kontrol level subwoofer
* Konverter D/A 24-bit
* Pemulih Suara (Sound Restorer)
* Pengatur suara Digital Z-Enhancer
* Ekualiser parametrik 2-band
* Penguatan bas dinamik MAGNA BASS EX
* Filter high-pass & Low-pass terpasang
* Pengatur pembatalan amplifier terpasang
* Amplifier MOS-FET 4-kanal × 53 watt
* Konsol lipat
* Layar 2-baris menyolok dengan screensavers
* %u201CSLIDETRAK%u201D untuk kontrol volume dinamis
* Input seluler dan mode bisu telepon
* Input auxilliary dengan kontrol level
* Audio pre-out 6-volt/6-kanal
* Kontrol CeNET untuk : DVD changer, TV tuner, CD changer 6-cakram dan iPod®
* Kemampuan antarmuka roda putar kabel jarak jauh OEM
* Transiever AUX Bluetooth siap digunakan untuk tipe BLT370
* Kontrol panel yang dapat dilepas
1 lagi dRI jvc TYPE KD-G 635 ATAU 735 ( FULL FACE )
* Power Output: 50W x 4 Max
* MOS-FET Power Amp
* 24-bit DAC
* 3-Band iEQ
* Ready for iPod*
* *KS-PD100 required
* MP3/WMA Compatible with ID3/WMA Tag
* USB Port (MP3/WMA)
* J-BUS Terminal
* Line Output Terminals (x 2 pairs) with Rear/Subwoofer Output Switchable
* Subwoofer Level/Frequency Control
UNTUK KETERANGAN LEBIH LANJUT DAN PEMBELIAN ONLINE LANGSUNG KLIK http://WWW.AUDIOMODIF.COM
* Konsol lipat
* MOS-FET Power Amp
* 24-bit DAC
* 3-Band iEQ
* Ready for iPod*
* J-BUS Terminal
http://www.audiomodif.com
kalijudan 110 - 112
Surabaya - Indonesia
OFFICE :031-3895098
MATRIX :08155104085
Pro XL :081938087722
MSN : [email protected]
YiM :[email protected]
e-mail : [email protected]
kalijudan 110 - 112
OFFICE :031-3895098
MATRIX :08155104085
- SM Affiliate
Sony CDX-50IU sama CDX-GT660US .. sptnya tampilan lebih keren yg GT660US deh .. kenapa bisa lebih bagus CDX-50IU? apakah krn Integrated iPod® Connecter supplied ... trus FREE USB CHARGER itu apa yah?.. USB Flashdisk ato apa? .. kualitas suara kedua type ini mana yg lebih bagus?
Kalo JVC 735 dg 635 sptnya .. lebih bagus yg 735 ya... beda lumayan harganya, .. tp kualitas suara gimana? bagus JVC ato Sony?
Dari semua yg diinfo.. mana yg terbaik?
bos audiomodif tertarik jadi rekanan club ga?.. kalo berminat.. tar gw kirimin email resmi dari NLC.
MONZA-AUTOSPORT.COM
WA: 08129215600
WA: 08129215600
saya sih ga terlalu ahli dalam hal audio boil,cuma dari kubu jvc cukup banyak pilihannya untuk rentang harga dibawah dua juta dengan kemampuan seperti usb,mp3,n etc.sya pake dah 3 tahun masih awet-awet saja,cuma mungkin jvc lemah motornya kali ya,kalo cd hasil burn-sendiri kadang suka "nyantol" ga mo eject.rencananya juga pengen tuker lagi,kemaren lihat jvc,tapi tipe apa ga tahu,tapi komplit mulai dari usb,dvd,mp3,vcd.trims
Kayaknya JVC ok tuh bro maxx, saya juga pake. Cuman harganya emang lebih dikit dari budget bro maxx (2,5 jt), saya lupa tipenya. Soalnya boil dirumah (jawa tengah) sedangkan saya di kerjaan (jatim). Spt yg ditulis bro swift, dia bisa baca dvd (single DIN single Disc) dah pake remote. Katanya ini HU yg cocok bagi yg mau coba bangun medium car entertainment, tinggal (nyicil) nambahin monitor, power, etc, etc.
Ato coba browse ke link ini deh (dijamin tambah bingung dan ngiler...):
http://www.audiomobilshop.com/
- SM Affiliate
imsus2c wrote:Kayaknya JVC ok tuh bro maxx, saya juga pake. Cuman harganya emang lebih dikit dari budget bro maxx (2,5 jt), saya lupa tipenya. Soalnya boil dirumah (jawa tengah) sedangkan saya di kerjaan (jatim). Spt yg ditulis bro swift, dia bisa baca dvd (single DIN single Disc) dah pake remote. Katanya ini HU yg cocok bagi yg mau coba bangun medium car entertainment, tinggal (nyicil) nambahin monitor, power, etc, etc.
he eh.. bikin ngiler nih.. tar saya samperin aja langsung ke kantornya di sunter.. kebetulan dekat dg rumah ..
Makasih om inputnya!!
Tp tetap.. mana yg terbaik u/ dipilih?
MONZA-AUTOSPORT.COM
WA: 08129215600
WA: 08129215600
Saran nih.....
kalau mau komplit n ready semua pakai Sony GT-50UI.
kalau mau suara lebih bagus, cuman feature IPOD ngga ada, but harga lebih ,murah pakai JVC yang 735. dah full face lage....atau 635 yang ngga full face.
trus kalau bener2 memperhitungkan suara yang lebih...pakai clarion 576usb ( IPOD ngga ada )
gimana?
gimana?
kalijudan 110 - 112
OFFICE :031-3895098
MATRIX :08155104085
kalijudan 110 - 112
OFFICE :031-3895098
MATRIX :08155104085
itu TYPE JVC yang DVD pak. barang baru masuk type KD-DV7035/6
kalijudan 110 - 112
OFFICE :031-3895098
MATRIX :08155104085
kalijudan 110 - 112
OFFICE :031-3895098
MATRIX :08155104085
- SM Affiliate
Yup.. lagi nimbang2... HU 1 DIN.. Sony GT660US / SONY GT-50UI / JVC G735 + VidiQ PDQ700audiomodif wrote:Saran nih.....
gimana?
Ato pake dual DIN Sansui SN-DM690ST.. Touch 7" screen ... merk jepang (tp mungkin udah buatan china jg).. harganya bersahabat ...
PM gw dibales ya bos...
MONZA-AUTOSPORT.COM
WA: 08129215600
WA: 08129215600
Check PM boss
kalijudan 110 - 112
OFFICE :031-3895098
MATRIX :08155104085
kalijudan 110 - 112
OFFICE :031-3895098
MATRIX :08155104085
- SM Affiliate
Nih bantuin dong .. antara Sony GT660US vs Sony GT50UI vs JVC G735 ... kualitas suara bagus mana?
MONZA-AUTOSPORT.COM
WA: 08129215600
WA: 08129215600
- SM Affiliate
HU yg mana om?imsus2c wrote:@audiomodif
emang itu tuh barang yg saya pake. Kualitas dan fitur ok sekali. Sayang...belum saya upgrade lagi...alias belum ada power, subwoofer, monitor, etc...etc...
MONZA-AUTOSPORT.COM
WA: 08129215600
WA: 08129215600
JVC KD-DV7305, barangnya persis sama foto yg diupload boss audiomodif. Dah ta coba colokkin USB (berisi lagu2 MP3, kira-kira 400 lagu/track) merk transcend kapasitas 2GB, dia baca dengan lancar (ga error)
Ta coba DVD bajakkan pun masih baca , ya setidaknya suaranya keluar deh...kan belum dipasang monitor...
Re:
ada pioneer DEH - 3050MP di http://www.audiomobilshop.com/ryanzaul wrote:ada saran utk yg 1din yg bisa mp3 + usb yg harganya < 1jt?
thx banget
Lacak, Dengarkan Percakapan, Matikan Mesin
dengan SuperSpring GPS Tracker
Tiga Langkah Mudah Mengamankan Kendaraan.
021 54 360 360
http://www.superspring.co
021 54 360 360
Re: Re:
blom usb bro...mainstream wrote:ada pioneer DEH - 3050MP di http://www.audiomobilshop.com/ryanzaul wrote:ada saran utk yg 1din yg bisa mp3 + usb yg harganya < 1jt?
thx banget
yang udah itu 4050 ub
kalo kurang dari 1 juta baru kayaknya agak susah juga ya...
Bisnis? Sini donk..
Bisnis? Sini donk..
Re: Pilihan HU 1Din terbaik (bs CD, MP3, USB) harga <2jt
Wihh yg bisa USB MP3 segala kalo dibawah 1jt boljug tuh... Lg nyari jg
ID42NER - TOYOTA FORTUNER CLUB OF INDONESIA
http://www.id42ner.org | http://groups.yahoo.com/group/id42ner | http://fortunerforum.fr.yuku.com/
wah tunggu aja bro 1 taun lagi... anti juga turun..
kalo 3050 mau yang USB tuh 3050UB.. jangan yang MP..
Bisnis? Sini donk..
Bisnis? Sini donk..
Kalo player dvd bisa gak baca dvd yang isinya mp3? Apa cuman dvd film?Quote:
Hampir semua seri player dvd yg sekarang beredar udah support read MP3, DVD/CD Rtzalie wrote:Kalo player dvd bisa gak baca dvd yang isinya mp3? Apa cuman dvd film?Quote:
wait ajah deh... klo sempet seh.. see
kalo saya sih, soal dengerin musik cenderung pake HU/player yg model USB ajah... Player di boil hanya buat "muter" USB stick (bukankah namanya UFD = "U"sb "F"lash "D"isk?) ato radio. Hampir ga pernah muter cakram (CD/DVD). Teori pribadi neh..., bisa memperpanjang umur player/HU, soalnya kan motor cakram ga kerja trus mata laser juga nganggur. Sedangkan kalo "muter/play" UFD, dapat dikatakan tidak ada komponen mekanis HU yg bekerja. CMIIW
Saya pernah muter lagu di DVD 1 jam lebih, waktu selesai, disc ta keluarin...terasa panas/hangat sekali tu disc-nya. Saya ga tau apakah HU-nya yg bermasalah ataukah memang normalnya begitu. Jadi takut muter disc lagi, makanya sekarang mendingan pake UFD, dah punya 3pcs @2GB di boil, kalo mo didengerin semuanya, nyetir jakarta-surabaya pun blom habis tuh isi/content lagu mp3-nya...hehehe.....
kalo pengalaman ogud pake merk cina sih, cd isi file picture pun kebaca..
bahkan dulu mau pindahin film pake cd juga bisa... filenya .mpeg
jadi kayak cd rom deh pokoknya.. hehehe..
Bisnis? Sini donk..
Bisnis? Sini donk..
nih ada seri terbaru dari PIONEER masih angetttt DEH-P6050UB, bisa USB maupun IPOD, motorized klo ngga salah...
kalijudan 110 - 112
OFFICE :031-3895098
MATRIX :08155104085
kalijudan 110 - 112
OFFICE :031-3895098
MATRIX :08155104085
brapa tuh harga DEH-P6050UB & DEH-P5050UB ???audiomodif wrote:nih ada seri terbaru dari PIONEER masih angetttt DEH-P6050UB, bisa USB maupun IPOD, motorized klo ngga salah...
