Review : MyGreenOil
alex99
Review : MyGreenOil
Post by alex99 »
ada yang udah pernah coba MyGreenOil? kalo ada tolong kasih commentnya dong
ini Product Overviewnya
MyGreenOil is a Multifunctional Breakthrough Fuel Reformulator. When mixed with fuel, it immediately changes normal fuel, making it a super efficient fuel which performs at optimum value, resulting in multiple benefits such as:
FUEL SAVINGS - from the ever increasing cost of fuel
INCREASED POWER & PERFORMANCE - giving optimum value for net gain against cost
REDUCED MAINTENANCE COSTS - from expensive engine wear and tear
REDUCED EMMISSIONS - from harmful toxic exhaust emmissions
MyGreenOil can reformulate any kind of liquid fuel such as; petrol, diesel, light fuel, medium fuel, heavy (bunker) fuel or biodiesel.
MyGreenOil creates immediate economic savings when used for cars, trucks, boats, motorcycle, diesel powered engines, generator sets, lawn, garden and farm equipments, furnaces, burners, boilers and all kinds of industries that use large amounts of fuel.
MyGreenOil is a unique formula of high-quality natural esters. It is non-toxic, non-hazardous and free of carcinogens. The unique natural esters in MyGreenOil is made up of 100% plant quintessence, it is not derived from petroleum and is biodegradable. Laboratory tests confirm that MyGreenOil is clean and safe upon ignition, reducing emissions without adding any of its own components to the exhaust and is 99.999% ash-less upon combustion.
Fuel Savings From Reduced Fuel Consumption
In normal circumstances, fuel in any engine burns incompletely and gets worse as the engine gets older. This inefficient burn leaves unburned wasted fuel, which becomes dangerous hydrocarbon exhaust emissions polluting the environment. Exhaust is essentially unburned fuel or wasted fuel. Besides exhaust gases, inefficient combustion also creates carbon build up in your engine, which robs power and performance from the engine.
When MyGreenOil is added to normal fuel, oxygenation occurs at the molecular level changing normal fuel to become high quality super efficient fuel, allowing it to burn more completely in an efficient manner. Less wastage and more efficient burning results in reduced fuel consumption and translate into better mileage for every tank. Instead of being exhausted in the form of toxic emissions, unused fuel is now saved in the fuel tank, waiting to be used efficiently by the engine. Efficient fuel use also means improved engine performance. On average, our customers have reportedly achieved a 15% to 50% increase in fuel mileage. Increased mileage creates fuel savings by producing a net gain in mileage above cost.
Increased Power and Performance
Efficient combustion means efficient fuel use which translates into improved engine performance. A more complete combustion process obtains increased power from each engine revolution. Tests have proven that when MyGreenOil is added into fuel, it is able to increase horsepower, torque and acceleration, without the usual side effects such as high engine temperatures, louder engine noise and increased wear. In fact, MyGreenOil is proven to do just the opposite. While Power and Performance improves, engine temperature, noise, vibration, wear and tear becomes significantly lower, protecting the engine in the long run.
Reduced Maintenance Costs and Prolongs Engine Life Span
MyGreenOil is proven to provide savings from high engine maintenance and repair costs. The unique blend of 100% natural esters adds lubricating and cleansing properties to the fuel.
Internal components of the engine benefit from the lubricating and cleansing properties of MyGreenOil, this includes the fuel lines, filters, carburettors, spark plugs, injectors and all engine seals, keeping them tighter and longer lasting.
Engine lubricant oil still appears clear and clean after more than 10,000 kms BEFORE
without MyGreenOil (15,000 km) AFTER
with MyGreenOil (15,000 km)
The cleansing properties of Natural Esters in MyGreenOil also prevent new carbon deposits and remove old deposits, which robs the engine of power and performance. As a result, horsepower and torque returns closer to the manufacturer’s specifications. Less carbon also results in cleaner and longer lasting spark plugs and engine oil lubricants, providing significant savings on maintenance costs.
After several weeks of continuous use, these natural esters which have very small molecular structures starts penetrating the imperfections on the metal surfaces of the engine, forming a lubricating layer of film between all moving surfaces. As a result, the engine begins to run noticeably smoother with less power-robbing friction and heat. Engine performance & engine efficiency continues to improve measurably, over a period of months.
A cleaner, more lubricated engine runs at cooler temperatures and runs smoother with unnecessary vibrations, protecting the engine from expensive repairs and requiring less maintenance while extending its life.
Reduce Harmful Emissions and Helping The Environment
MyGreenOil provides an immediate, cost-effective strategy for fighting air pollution and greening our planet. The unique reformulation process causes fuel to burn more efficiently and optimises combustion. This significantly reduces harmful toxic exhaust emissions.
MyGreenOil is non-toxic, non-hazardous and free of carcinogens. The unique natural esters in MyGreenOil is made up of 100% plant quintessence, it is not derived from petroleum and is biodegradable. Laboratory tests confirm that MyGreenOil is clean and safe upon ignition, reducing emissions without adding any of its own components to the exhaust and is 99.999% ash-less upon combustion.
When MyGreenOil reformulates fuel, exhaust emissions have been proven to be reduced by more than 80%. Other emissions reduced are hydrocarbons (HC), nitrogen oxides (NOx), carbon monoxide (CO), particulate matter (PM) and other harmful by-products of combustion.
MyGreenOil is making a difference in the world by making the air of our environment cleaner. It is the easiest, fastest, safest and most cost effective way of reducing air pollution resulting from vehicles and industries that burns fuel. Anyone can make a difference in air quality and protection of the environment immediately by just adding MyGreenOil into their fuel tank. Unlike other environmental solutions, MyGreenOil does not require expensive equipment, complicated installations or modifications to immediately benefit from it.
http://www.mygreenoil.com/home.html
WiraSoenaryo
Administrator
Administrator
Daily Vehicle: Toyota Rush TRD
Re: Review : MyGreenOil
Post by WiraSoenaryo »
Hallo,
Judul topik saya rubah, agar lebih sesuai dengan isinya.. :)
Sekian, terima kasih.
Our other services
satyr
Post by satyr »
kalo ada yg mo kasi gw sample
tar gw review deh
tar gw cobain di twincam gw (sehari2 pake premium)
poeticmind
Post by poeticmind »
my green oil ada yg jual di bdg? hmmm, increase powernya diragukan... kalo reduced emission oke lah, namanya juga green oil, kan..
alex99
Post by alex99 »
satyr wrote:kalo ada yg mo kasi gw sample
tar gw review deh
boleh ntar gw kirim sampelnya
tuker ama GE Megalight Plus yak
poeticmind
tar gw review deh
waks! semahal itukah harganya? waduh... ck ck ck... :e-think:
satyr
Post by satyr »
knapa gw ga mau beli..soalnya dulu coba extra power jg ga kerasa efeknya --'
Sugie
Post by Sugie »
poeticmind wrote:my green oil ada yg jual di bdg? hmmm, increase powernya diragukan... kalo reduced emission oke lah, namanya juga green oil, kan..
Ada bro, gw dah coba........... :D Biasa gw pake Shell Super, tapi dah 2x belakangan ini gw isi premium + mygreenoil. Kalo buat irit sih kayanya ga ada bedanya sm waktu gw pake Shell. Buat power, kayanya berkurang dikit dibanding sama waktu gw pake Shell; kerasanya di Cipularang......Mungkin perbandingannya lbh keliatan antara kalo pake premium doang and kalo pake premium + mygreenoil.
Shaqilla
Post by Shaqilla »
Gampang aja jawabnya: sori ndak percaya!
Apri-AIC212
satyr
Post by satyr »
kesimpulannya premium + MGO blom bisa tandingin pertamax
walau mungkin ada improvement dari sisi keiritan BBM (biasanya kalo pake premium lebi boros)
CMIIW tapinya :D
poeticmind
hmm, irit tapi no power? kok bisa ya... bejek gas, ya boros bro? hehe...
satyr
Post by satyr »
ga ngerti.. gw pernah coba extra power jg no effect
poeticmind
hmmm masuk akal, bro... meski saya masih ragu nih... :P
remedusakti
Post by remedusakti »
ada ga yang dah tes tapi secara objektif, jd bukan cuma perasaan aj coz parameternya ga jelas. udh ada belum test dr pihak independent ( bukan dr pihak MGO ), test mobil dengan MGO dengan parameter emisi, kenaikan tenaga or torsi berupa grafik, test keiritan BBM ?? yah minimal produsennya lah yg bkn test kl belum ada pihak independent, so bs lebh meyakinkan bagi calon pembeli sebagai makanan tambahan buat mobil. kl cuma claim tulisan n omog doang yah sapa yg mau percaya..
Sugie
Post by Sugie »
Gimana kalo kita barter aja bro, nanti kalo gw ke garasi gw bawain mygreenoil, terus barter ama bardahl..... :D
poeticmind
Sugie wrote: Gimana kalo kita barter aja bro, nanti kalo gw ke garasi gw bawain mygreenoil, terus barter ama bardahl..... :D
good idea!!! :off_good:
sharpshooter
Post by sharpshooter »
Bro, buat yg beli ginian, atau apa pun yg claim bisa hemat BBM, suruh istri atau org rumah elu yg masukkan ke tanki bensin sebelum elu isi full tank / mau test. Jadi elu gak tau udah di isi belum, jadi gak sugesti, wah mobil terasa enteng, terasa hemat bbm, krn parameter setiap hari berubah bro, kondisi cuaca, kemacetan,berhenti2 dimana,nanjak tidak, dll, kalo cuma pake perasaan, itu tdk tepat bro.
Lalu kalo mobil yg dipakein rusak, gimana?
oooooooooooo...tenang, ada asuransinya, bahkan ada yg claim sampe 2 Miliar, nah tolong 'SYARAT & KETENTUAN NYA' di upload yg jelas, claim kemana, telp nya brp dan alamat urusnya kemana, jgn2 harus ke Malaysia, krn ini product sana.
Gw tertarik, tp gak mau coba2 dah, sementara ya gaya nyetir saja yg lebih wise.
poeticmind
@sharpshooter : iseng doang bro... bukan soal hemat nya, hanya penasaran saja.
kalo soal hemat BBM, saya sih udah ga peduli... sampe 50rb/liter juga resiko. ya ga? hehehe! :)
mesin sih saya yakin kuat diapa2in juga, mobil saya udah ga asuransi... hehehe, kalo jebol yo wis... paling garuk2 kepala...
kalo tertarik coba aja bro... toh kalo ga cocok tinggal distop balik ke bbm normal. :)
Shaqilla
Post by Shaqilla »
sharpshooter wrote:Bro, buat yg beli ginian, atau apa pun yg claim bisa hemat BBM, suruh istri atau org rumah elu yg masukkan ke tanki bensin sebelum elu isi full tank / mau test. Jadi elu gak tau udah di isi belum, jadi gak sugesti, wah mobil terasa enteng, terasa hemat bbm, krn parameter setiap hari berubah bro, kondisi cuaca, kemacetan,berhenti2 dimana,nanjak tidak, dll, kalo cuma pake perasaan, itu tdk tepat bro.
My Green Oil memang ada perlindungana asuransi Product Liability namanya.. tapi dari Allianz Malaysia, hiks... bukan dari Allianz yang di Indonesia...
Apri-AIC212
JESKONENG
Post by JESKONENG »
sampai skarang blum ada agen/toko di Jogja yang jual MGO yaaa ?????
Norival Fuel Enhancer
FB (id : Torry Parantoro)
hp/WA : 081328516999
poeticmind
wah om JES... masa semua mau dicoba ya? hahaha!
Shaqilla
Post by Shaqilla »
Demi project 180HP di L15A n/a katanyah.....
.........kabuurrr...........
Apri-AIC212
poeticmind
ooooooh gitu... wakakaka! MGO model apa bisa naikin HP, bro?! hahaha
Shaqilla
Post by Shaqilla »
poeticmind wrote:ooooooh gitu... wakakaka! MGO model apa bisa naikin HP, bro?! hahaha
MGO tambah temennya yg juga 3 huruf.... NOS, huehehe.....
Apri-AIC212
poeticmind
naaaaah, pengen juga tuh bro... buat iseng2. mobil standar dipasang ginian bisa ga? :P
