All-New BMW M5
The M division unleashes a V-10 monster
July 2004
Powertrain
New 90-degree V-10 with 507 horsepower and 383 lb-ft of torque (European measure)
Redline: 8250 rpm
One hundred horsepower per liter of displacement
Double-VANOS variable valve timing
Electronically controlled throttle butterfly for each cylinder
MS S65 engine management system features most powerful processors currently approved for use in automobiles
Seven-speed SMG transmission with steering wheel shift controls
Twenty percent faster shifts compared with last-generation SMG
Drivelogic with eleven program options that enable shift characteristics to be tailored to suit the driving situation and the moodâ€â€six of these programs can be selected in the sequential manual gearbox mode (S mode)
Chassis
Aluminum suspension
Nineteen-inch wheels with performance tires
Variable M differential lock delivers power to the drive wheel with the most traction even in extreme driving situations
Dynamic Stability Control
Electronic Damping Control with three program modes (comfort, normal, sport)
Perforated compound brake discs
Aluminum twin-piston brake calipers
Styling
Modified front spoiler, rear apron, side sills
Larger wheel arches for bigger wheel and tire package
More-aerodynamic exterior mirrors
Four tailpipes
Exclusive wheels
Gills incorporated into the front fenders
Exclusive leather interior with sports seats
Unique M-style instrument cluster, center console, steering wheel, optional head-up display
'06 BMW M5
'06 BMW M5
ini mobil yang ngak ada mati nya.
di koran ada yang jual nih di jkt cuman yang e39 tahun 2002 M5 juga cuman model lama.
hp nya 400 an bok ck ck ck sekali tekan badan langsung kehempas bawa ini ngak kuatt.
padahal ngak pakai turbo charger cuman gila gila an tenaga nya.kalo udah punya ini ngapain berpaling kelain hati hehehe
Oh my God.
Dengan 507 HP berapa kira2 max speed yg bisa dicapai ya?Lbh 250KPJ?
Next question,dimana dijakarta kita bisa "menerbangkan" mobil secepat itu?
Hehehe silly question
Divisi M5 ini memang luarbiasa kinerjanya.
Mercy juga punya kan....(brabus?)
Avanza@2006>>>
Innova@2010>>>
EcoSport@2014 >>>
Black VRZ@2016
