Peugeot 4002
Stefan Schulze satisfied each of the three requirements with his Peugeot 4002. Identification with the Marque is immediately apparent.
Indeed, the Peugeot 4002 is a Peugeot by hint of the design of its headlamps and its general character, which is resolutely dynamic. In addition, by adopting one of the Marque’s most characteristic stylistic features, namely the large radiator grille behind which are concealed two headlamps, the project by the young German graphic artist immediately reveals the source of its inspiration, the Peugeot 402 dating from 1936.
Finally, the symmetry accorded to the front and rear, and its architecture, which assigns a very forward position to the passenger compartment, make the project particularly original.
The overall effect is paradoxical: soft, elegant contours and seamless transition produce a highly resilient car, resting solidly on its 21 inch wheels.
For the Peugeot 4002, Stefan Schulze made extensive use of chrome. The grille, the arch that "joins" the front to the rear of the concept car, and the side louvres were produced by means of a low press casting technique known as "choupage". This consists of pouring a layer of molten aluminium alloy into a mould shaped according to the required part. The component is then reinforced with a fibreglasscharged resin.
Aluminium parts are then polished and mounted on the concept car. The exhaust nozzles, door mirrors, air intakes and 21 inch wheels further enhance the exclusive character of the Peugeot 4002.
A final assembly operation is devoted to the engine cowling. The latter is installed centrally, lengthwise, in front of the rear wheels. A carbon cover is then placed on top, leaving visible specific intake pipes that strengthen the retro feel sought by Stefan Schulze.
Text and photos courtesy of Automobiles PEUGEOT
Peugeot 4002
Peugeot 4002
I love This Car !!! Futuristik banget !
Matanya juga menyiratkan keganasan mesinnya.
Saya pernah liat neh mobil di TV dalam acara AutoMundial. Dan mobil masa depan dari Peugeot ini memang designnya bagus banget. Peugeot memanggil para designer dari berbagai dunia, dan ada salah satu designer yang hasilnya bagus. Kemudian Peugeot membuatnya ke dalam bentuk konsep car (dari campuran tanah liat dan kemudian di cat oven). Nah hasilnya spt yang diatas.
Konsep car dari guratan di atas kertas yang kemudian dibangun dari tanah liat. Keren juga !
